how to save money on FOB?
Discussion in 'Gen 2 Prius Main Forum' started by coyote2, Oct 14, 2014.
  1. coyote2
    coyote2 Member
    148
    36
    I need to replace one of my FOBs. (It drains batteries fast, apparently due to a stuck button.)
    Is there an easy but frugal way to get a new FOB?
    For example, if I get a used one (I see one online for $63 shipped), how much would a dealer charge to program it for my Prius?
    (As for the key, I can just cannibalize my existing FOB.)
  2. JC91006
    16,936
    8,647
    Free the button with a sharp exacto knife or utility knife
    52,812
    there are many threads here on replacement fobs. some more successful than others. sorry i can't point yo to a successful one, all the best!(y)
  4. coyote2
    coyote2 Member
    148
    36
    Thank you very much for your reply, JC91006, but I can't free the button because none seem/appear to be stuck (this is just the best theory offered in the other thread).
    So I think I'll go ahead try whatever is recommended. I just phoned my dealership and they said if the used one I get is good a reprogram would cost me $79.50. I can deal with that ($63 + $79.50)(though it will hurt because I'm on disability) because I need a good 2nd FOB now.
  5. bisco
    52,812
    yes, you don't want to lose your only fob that gets real expensive.
  6. JC91006
    16,936
    8,647
    You are probably just buying inferior batteries.
    You should buy a new fob from amazon for $118 and program it yourself.
    I have never heard of a dealer programming a used key for only $80. They normally charge more for used key programming (if they can even do it), new key programming normally is over $120
  7. coyote2
    coyote2 Member
    148
    36
    I think not, since the same batteries last for years in my good FOB as I mentioned in the thread linked to above.
    Thank you very much JC91006, perhaps I shouldn't risk $63 on a used one. And I didn't realize that self programming was an option!
    They did warn me it might not work, and mentioned in that case one might chose to pay $190.80 to reset the computer.
  8. JC91006
    16,936
    8,647
    Yes you can do it yourself for FREE.
    How to Program a New Key Fob for Full SKS Functionality | PriusChat
  9. coyote2
    coyote2 Member
    148
    36
    Sweet! I'll but that $118 Amazon FOB asap! Thank you so much!!
