How to see estimated oil life?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by techno-Zen, Apr 23, 2013.
  1. techno-Zen
    techno-Zen Junior Member
    Mesa, Arizona
    I bought my Prius about a month ago.. I forgot to ask when the last oil change was. :/ my fault.. but now I would like to know.
    will my car simply notify me when it's time to perform maintenance?
    Thanks!
  2. Charlie Bravo
    Charlie Bravo Junior Member
    New Orleans
  3. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    If it's used, might as well change it to start off fresh.
  4. Bill Norton
    Bill Norton Senior Member
    2,244
    754
    MONW, Ks.
    2019 Prius
    L Eco
    You get a 'Oil maintenance Require' message on your display, IF the 5000 mile counter was reset at that time.
    The oil change interval is now officially 10,000 miles if synthetic 0w-20 oil is used.
    However the message pops up and has to be reset at 5000 mile intervals.
    It's all there in your manual...
  5. Sfcyclist
    1,621
    376
    SF, CA
    right, but he bought a used car. who knows if it was reset on time.
  6. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    If the onboard computer does not display the maintenance schedule and you are unsure of the previous entries, just take a sample from oil gauge (few drops on fingertips) - if it is black, dirty and smells of ... hmm. dirty old oil with a touch of gasoline - replace it.
  7. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,789
    Bay Area
    Just change your oil and you won't have to worry about when it was last change. You would rather have a peace of mind knowing that its been changed rather than guessing if it has or has not :)
  8. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    He will also then know what oil is in his engine.
    Les_PL likes this.
  9. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    Change the oil/filter and ATF now. Always reset a used vehicle. You are buying someone else's probable abuse and you can always trust the seller...right? :rolleyes:
    Les_PL likes this.
  10. techno-Zen
    Mesa, Arizona
    Well, it was previously leased up to 36k miles, and sold from a toyota dealer so I just assumed.
    The oil looks clean on the dip stick.
  11. frodoz737
    4,805
    2,561
    33
    My recommendation stands. Your car, your choice. ;)
  12. fuzzy1
    10,707
    The reminder comes on at 4500 miles (and every Start thereafter), and times out. Then it changes to a more stern warning at 5000, which doesn't time out, though you can change displays to get back to the regular displays.
  13. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Never assume without proof of service done to the vehicle. Rather be safe than sorry :)
  14. The Dude
    The Dude Member
    197
    32
    Phoenix
    car doesn't automatically know by detecting that your oil needs to be changed, its just set to alert you when you reach certain mileage. i think you should change it sooner than later, but have you checked the oil level and the condition of the oil yourself? warm up the car by driving it for a few miles, wait a few mins, then check oil.
  15. techno-Zen
    Mesa, Arizona
    I found the carfax on my car, full maintenance was done 01/09/2013 - Wasn't driven until I bought it so I should be good. I just thought there may have been a way to check. My old Honda would tell me in % what my oil life was.
  16. frodoz737
    4,805
    2,561
    33
    At 36,000 full maintenance as defined by Toyota for the Prius amounts to nothing more than oil/filter change, rotate the wheels, and give it a once over. As it applies to reselling a lease return, they do a quick detail (clean it up). Nothing more than a visit to Jiffy Lube with a car wash. If you trust the seller/Dealership, at minimum have the transmission fluid changed. The need is well documented by 30,000 miles, or sooner for Mechanic/Owners like me. I realize some level of faith is expected, but have everything check over once more by a third party. All used car sales departments are motivated to spend/do the least amount to maximize high profit and a quick sale.
  17. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Keep the filter and just dump and refill 4qts.5min job
  18. NutzAboutBolts
    1,756
    1,789
    Bay Area
    Oil life % is the same as another maintenance reminder, it doesn't actually know your oil life, it just estimate by your mileage and just indicate the oil life %.
    Since you have the carfax info and the oil has been changed since January, change your oil every 6 months or 10k miles with synthetic oil 0-20w.
  19. frodoz737
    4,805
    2,561
    33
    Respectfully disagree with this bad practice. There are some applications where you might change the filter and not the oil, but not here. You should always change the oil and filter together on your Prius. Why run fresh clean oil through a dirty filter which may hold around a 1/2 qt of old oil as well. Bad habit and only takes a couple extra minutes to finish the task.
    Change the ATF techno-zen.
    almypal26 likes this.
  20. tankyuong
    1,555
    662
    Central MO
    Better than the oil he's got
