how to start prius in cold weather?
Discussion in 'Gen 3 Prius Main Forum' started by jae um, Jan 3, 2013.
  1. jae um
    jae um New Member
    when i start my 2012 prius 2, it starts with motor (no engine sound)
    then reverse mode to get out of my parking lot, it starts engine
    should i wait until engine (yes actual engine with loud sound) start? or just drive right away with battery and let the car start engine?
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    506
    201
    Maine
    The Prius is smart. It knows what it wants, and it will do what is best for it. Just drive and be happy. :)
    We are beginning to see cooler weather [negative F temps] which is perfectly normal, and our Prius is handling it perfectly.
    OceanEyes likes this.
  3. southernguy
    southernguy Junior Member
    55
    I have found that if I leave the prius in the driveway to warm up a bit my mileage doesn't suffer near as much as if I just get in it and go.
  4. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Interesting, I'm very interested if there is any facts or logic to this post. I'll be paying attention to hear from the experts!
  5. southernguy
    55
    All I know is, if I just get in it and go, by the time I have made it a few blocks my battery is in the purple zone or almost and I drop a few mpgs. When I let it sit and warn up a few minutes neither of those two things happens nearly as much (i.e. battery drain and mpg hit.)
  6. tankyuong
    tankyuong Senior Member
    1,141
    469
    Central MO
  7. has been
    has been buy local, support your community
    251
    46
    pacific n'west
    The Prius runs it's best at a certain temp.
    It will get to that temp asap.
    It will run longer (ICE) if there is a demand for cabin heat to help satisfy that temp request.
    That's why people use pre-heat devices in winter.
    But basically it's like beekeeper said, just drive it and be happy.
    The Prius will take care of itself, it knows what it's doing.
  8. OceanEyes
    OceanEyes Active Member
    527
    423
    Southeastern Connecticut
    Same here with the car adjusting to whatever I throw at her - but a slight warm up in temps got me back into the MPG ranges I try to find during today's errands....
  9. OceanEyes
    527
    423
    Tried the "warm up" sequence and the ICE runs for a bit and goes to electric mode and mine is garaged with an interior temp ranging from 46 F to 50 F. Definitely a car with a mind of its own...
  10. Ridder
    Ridder Member
    141
    51
    Netherlands
    AFAIK reverse is always electric.
    Maybe the ICE is running to warm up the cabin, and more important: get the catalyst to operating temps.
  11. cwerdna
    cwerdna Senior Member
    12,539
    2,104
    SF Bay Area, CA
    Yep on both of the above.
    One doesn't need to wait for the engine to start to back up.
  12. Rebound
    Rebound Senior Member
    3,673
    2,241
    Portland, OR
    I've noticed that if I start the car with a full battery and the engine starts up to warm the cabin or because I've accelerated hard, mileage will be quite low, even though it's just caused by the engine idling to provide warmth. Because I drive about 80 miles a day, if I need morning cabin warmth, I switch out of EV and use my EV battery later.
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,303
    Wilmington, NC
    I have found that if I start the car and drive that the sooner I get the car up to temperature and start gliding that I can make up any mpg loss quicker than idling until warm. I have a 3 block drive through a residential neighborhood before hitting a 45 mph thoroughfare. By the time I accelerate up to 45 the engine is usually warm and I can start gliding or at least run in EV.
  14. southernguy
    55
    interesting. My mpg loss on 1/2 tank of fuel is almost 1 1/2 mpg when I jump in and drive and only about 1/2 mpg when doing warm up. Must just depend on the topography etc of where each person is located. I have a slight hill to climb within 1/8 mile.
    But bottom line is like has been said before...just drive the darn thing..it's a car.
Loading...
