How to stop a runaway Prius
Discussion in 'Gen 2 Prius Main Forum' started by PriusHighlander, Mar 9, 2010.
  1. PriusHighlander
    PriusHighlander New Member
    Los Altos, CA
    I'm a new member of this forum. Just had to post because I couldn't find a good source on the internet to learn how to stop a runaway Prius.
    I couldn't be happier with my 06 Prius or Highlander Hybrid. Neither have been recalled. I'm not here to debate whether this problem really exists, or what the cause is. I just wanted to discuss how to stop the car in the unlikely event that this were to happen.
    So...here we go:
    - I keep hearing put the car into neutral. It works fine if you are coasting without the accelerator depressed. I have found that this does NOT work if the accelerator is depressed. So if this is true, then all the crap you hear on TV or on the web about simply putting the car into neutral is useless. I'd be interested to know if others have found this to be the case.
    - Now, I have had the car go into neutral when I hit the PARK button with the accelerator depressed. So this could be a good way to stop the car. Has anyone else tried this and is this true?
    - Finally, I understand you can press the power button for at least 3 seconds to shut down the power. I have not tried this, but it seems as if there is a better way to do this without killing the power steering and the power, it would be preferred.
    Any other thoughts on this. And also, any thoughts on stopping an 06 Highlander Hybrid? It would be appreciated as well. Apologies if this has been discussed ad nauseum already. In my brief search, couldn't find good info.
    HOW TO STOP OF RUNAWAY PRIUS: SUMMARY OF INFO FROM THIS THREAD!
    1) Put the car into Neutral. You have to HOLD down the neutral for at least a little while and not just tap into into neutral.
    2) You can also press the "P" button. This will also put the car into Neutral if the car is moving and the accelerator is down.
    3) If 1 and 2 fail, try hitting the power button for a prolonged period of time (seconds). Keep in mind that you will lose power steering when the car shuts down.
    I find it amazing that despite all the publicity, this information is not well publicized. Spread the word to Prius owners.
    **edited to add summary
    6 people like this.
  2. David Beale
    David Beale Senior Member
    5,963
    1,983
    Edmonton Alberta
    The fastest and easiest way is to press the "P" button. It's right in front of you, easy to see, easy to get at. If you are moving over about 2-3 MPH the car will go into "N". If you are not moving the car will lock the drive train.
    The engine will drop to idle. BTW, -most- Prius will drop the engine to idle if you press hard enough on the brakes to light the brake lights. There is some indication that some don't do this, but that is to be tested.
    The Highlander Hybrid should function the same. It's the same "Hybrid Synergy Drive".
    But your best bet is to try it -before- you get a jammed pedal.
    3 people like this.
  3. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    When I heard the report on the radio this morning, I decided to try to see if it would go into neutral while accelerating. YES IT WILL!!! I floorboarded my 2007 Prius, held it to the floor as hard as I could while running down the highway @ 60+ MPH and threw it into neutral. **** IT WENT INTO NEUTRAL!! with no problem at all. The hybrid engine will not over-rev when it is put into neutral, it actually revs down. I did it twice just to be sure, yep, worked again. Try to rev your engine while in park, it won't rev quickly or very high. As far as shutting it off..... I haven't tried it, but push AND HOLD the power button to shut it down, don't just push it quickly or repeatedly push it. Anyway, imho the yesterdays incident is a load of stuff. I have had my 2007 Prius 2years and 9 months and 68k miles and had no problems other than it eating tires. Also we have had a 2008 Camry HYbrid for 2 years and 28k miles and no problems whatsoever, ... BUT they recalled it and put in an ugly black rubber floor mat and cut off the bottom of my gas pedal. My nice carpeted mat went back in when I got home, as did my heavy rubber winter mat.
    Well, now that I have ranted, I have NO PROBLEM with MY Toyotas!!;)
    4 people like this.
  4. deeno
    deeno Junior Member
    17
    I haven't tried powering off the prius while driving via holding the power button in (does this work at speed?), but does anybody know what would happen to the skid ECU (the braking computer) if the car lost power like this? I'm okay with the lack of power steering, especially at speed, but the loss of brakes would be bad.
    -edit- Thanks for testing putting the car into neutral and revving it. My lady is actually the Prius driver and I have no way of testing this stuff out without tipping her off that I have concerns about this
  5. PriusHighlander
    Los Altos, CA
    I will try the neutral thing again. When I tried it a while ago, it did NOT work on my 2006 WHILE the accelerator was down. If it does work, then this is the simplest way.
    However, I'm glad that someone else has verified the "P" button. I hit the P button accidentally once while I had the accelerator down, and the car went into neutral. This also seems like a really good solution.
  6. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    Replace Toyota logo with GM one. And will not run away anymore. :cheer2:
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    How to stop a runaway Prius? Drag your feet.
  8. CarGuy60
    CarGuy60 New Member
    50
    Boston
    Ogo, this was an interesting post with good following observations, till your crude comment. When thirty five or so people die driving Toyota's your post is out of line. May your Toyota always stop and perform as designed and not perform as other runaway Toyota's have.
  9. dspguy
    dspguy Junior Member
    49
    Boston
    To put it into neutral, you do have to hold it there for a second or so. Bumping it doesn't work, you need to hold it for a short time then it kicks to neutral. I've tried it with both a 2005 and 2009 while full out accelerating, and at various other throttle positions and it always went into neutral.
  10. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    I like the Park button method best.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Perhaps you didn't hold it in N. Shifting to N works even when accelerating.
    Pressing Park is the quickest method.
    Tom
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You could wait for it to run out of fuel?
    But then again, you could have a long wait :)
  13. yokonoge
    yokonoge New Member
    Chicago, IL.
    Can someone tell me? Does applying emergency brake while stepping on regular brake stop a runaway prius?
  14. paulemus
    paulemus New Member
    93
    San Diego
    My little runaway...
  15. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    What if it isn't the cars' fault these people died?
    How many people died driving Fords, Chryslers, & GMs?
  16. JimN
    7,028
    1,116
    South Jersey
    No. The parking brake is designed to hold a stopped car so it is very weak.
  17. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    Well, that is great news. I will have to try something similar:D
    But, everything was working properly. Who knows what will happen if there are gremlins in the computer and auto accelerates; will it behave as you indicated or have a mind of its own.
    That is the question.
    Have you tried that 'Parking' button method? That too may not work when the gremlins are at it.
    Doesn't need much pedal movement to light the break light.
    Thanks for that great feedback. I need to test this too. Hope it will respond properly when the emergency happens. Obviously that guy stepped on the breaks and nothing disengaged.
  18. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Your point is taken, but it's pure speculation. You might as well speculate that the gas tank will spontaneously explode. That the wheels might fall off. That the electric-power steering suddenly decides to reverse the sense of left and right.
    If the runaway situation occurs, these are the techniques that should work. If you're worried that they might not, you should leave the car in the garage.
  19. Superdrol
    Superdrol Member
    399
    32
    Rofl !!!!! I spit all over my keyboard b/c this comment.
  20. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    well thats some info to know. I had no idea you need to old the shifter in neutral for over 2 seconds to get the motor to spool down, then apply braking.
    I'm not to worried about sudden acceleration..but if it does happen at least i wont be like mr. Sikes
