How to stop Engine from turning on?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Troy Heagy, Apr 21, 2013.
Thread Status:
Not open for further replies.
  1. fortytwok
    fortytwok Active Member
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    70 mpg stinks plus you have to drive a car so ugly people want to ram it ;-)
    Just hit 1,000 miles on 2 gallons. Read is off as dealer had 20 gas miles on it
    seriously I did consider a Honda but my kids said it was too ugly
    rogerv likes this.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    :ROFLMAO: (y)
    52,855
    but we're back today, although, lowry did get screwed on that fowl to right.:whistle:
  4. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Its not nonsense figure, its just not the measure you seem to want to use. MPG is Miles per gallon.. it is a measure of gas used per mile and is very well defined. With a volt its easy to use little (and with a Leaf of Tesla use none in that vehicle so MPG is not well defined there). MPG (or better GPM is a good measure if as many my repub friends, your main concern is imported oil and amercian jobs. I've used under 30 gallons in the past 18 months.. how about you?
    You seem to want to use MPGe or some measure of energy used per unit distance.. something few people understand, clearly shown in other posts in this thread.
    A better model might be to talk about fuel cost per mile.. where I'm at at 0.028 $ per mile what are you getting?
    MPG$ which is the cost converted back to effective MPG at current gas prices where I'm over 165 miles per gallon dollar Equiv.. Its great for local comparison, not so much for Cali vs Co (where everything is more expensive in Cali)
    In my view, any day using is gas is a bad day.. and any month < 200mpg is bad.
    I'd go for all EV but if I had a leaf I'd use mor gas because I'd have to use the wifes Subrau for long trips.. instead we take the volt where we do 40s.
    fortytwok likes this.
  5. Troy Heagy
    Troy Heagy Member
    1,218
    Saying "I got 500 MPG in my Prius plugin! (or volt)" is the same as cheating. The owner failed to mention he also spent $80 last month on electricity. *All* the energy counts. It's the same reason I don't buy that nonsense about an EV being zero emissions or zero spent on gasoline (both energy and cost still exist; they are just displaced somewhere else).
    >>>"You seem to want to use MPGe"
    That is the official standard endorsed by the U.S. Government (EPA) and published across all electric or plugin cars. You act as if I pulled the idea out of my ___ but it has been around almost a full decade now.
  6. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Grrr! We'll get even with you in the playoffs!
  7. Rebound
    3,996
    2,645
    Portland, OR
    The electric utility here in Alameda, CA doesn't have SmartMeters, so they just rebate EV owners $15/month if we charge off-peak, using the honor system. My total Prius electricity cost is -$2 per month. (Yes, I know the difference between a - and a <).
    fortytwok and drinnovation like this.
  8. drinnovation
    2,027
    586
    65
    CO
    Using the term MPG properly is not cheating. The definition of MPG does not include costs nor does it include electricity. Is it cheating when a Diesel owener uses MPG .. since diesel has more energy per gallon? Is it cheating when someone choose to use some blened or even 100% Ethanol and gets lower MPG? MPG is well defined and is being properly used. If some people infer cost or energy from it, they are they ones that are wrong.
    I was not acting as if you pulled the ideas.. just your phrasing was not clear and you did not use the term MPGe in the post so I was guessing what you wanted.
    But since you say you want to count *ALL* energy, then you don't want MPGe.. that is just efficiency of energy used from the wall/pump. All energy would require full life-cycle analysis, including exploration, discovery, drilling, refining, transport, then wall/pump and should include the manufacture and disposal of the item as well. There are a few studies on EV/PHEV for on wells to wheels, but none that I know of that do a full life cycle analysis. (The Wells-to-wheels is misleading since for petroleum almost have the energy is use in the explore/discover/drilling phases, i.e. before there is a well. ) I guess one could do something like Energy-regurn-on-energy-invested per mile... ( hmm there is a paper in that. )
    Since I cannot know all the energy, I prefer to consider what matters to me cost..
  9. fortytwok
    467
    139
    Hopkinton MA
    2013 Prius Plug-in
    same here - also charging at the market, GE and chargepoint - my 31 days where I hit over 1000 miles on 2 gallons resulted in electricity charge to me of $19. His $80 is making assumptions that aren't valid
    what is valid is the Honda is still ugly and getting uglier everytime someone rams it ;-)
  10. bisco
    52,855
    i hope we make the playoffs! not confident after the last few years.:cool:
  11. Rebound
    3,996
    2,645
    Portland, OR
    Rule 5 of the PriusChat Charter!
  12. Troy Heagy
    Troy Heagy Member
    1,218
    Negative 2 dollars a month to charge the Prius Plugin? Wow. NICE. We don't get those kinds of deals in the northeast. In fact I've heard many people say they are paying over $1000 a month for their household electric bills.
    Here's an insght driver getting over 100 MPG. Put this guy behind the wheel of a 5-speed Civic Hybrid, and he could easily get 70MPG (maybe even as high as 80). Both these cars have lean-burn engines, where they have air:fuel mixes as low as 25:1
    Oh and diesels aren't just more MPGs. They use fewer BTUs/mile. Compare a gasoline Beetle (or Jetta or Gplf or Passat) to its diesel counterpart, and you will see they use about 25% fewer BTUs/mile.
  13. CharlesH
    2,798
    1,166
    Roseville, CA
    I wonder how the Honda "lean" mode compares to the "Atkinson Cycle engine" tweaks that Hybrid Synergy Drive does. As I understand it, it is not a "true" Atkinson Cycle engine, but they play some serious games with the valve timing to make it "Atkinson-like".
    What is the trade-off when using the Honda "lean" mode? Less horsepower?
  14. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Hi Troy,
    Aren't you just trying to make trouble? No one here rammed into your car. Is was someone else. You shouldn't assume that because a person that happened to be driving a Prius that it is someone here at PC.
    Why not stop with all the argumentative posts?
    I like all EVs and hybrids...I just like the Prius best. I don't really care what everyone else drives.
    Please take this in the right way...as a suggestion for a more enjoyable conversation.
    Mike
  15. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Acknowledged expert hypermiler Wayne Gerdes got 65 mpg in a Civic Hybrid. The OP has never substantiated his claim that top Civic Hybrid drivers get 70 mpg.
  16. Troy Heagy
    Troy Heagy Member
    1,218
    Lean burn is more accurately called "stratified charge". The top 2/3rds of the piston(near the sparkplug) has a standard 14.7:1 air:fuel mixture, but the bottom 1/3 has no fuel. So it burns one-third less fuel. Obviously I've simplified the explanation, but you can read more here. Honda has been using lean burn engines since the 70s: CVCC - Wikipedia, the free encyclopedia
    No THIS is the guy who started all the trouble. He'd probably love to load my Honda hybrid into a crusher. (And another toyota guy would press the "squash" button.)
  17. rogerv
    1,639
    317
    Still waiting for supporting evidence...........:sleep:
  18. Rebound
    3,996
    2,645
    Portland, OR
    Me! Pick Me! I've always wanted to press the "squash" button!
  19. bisco
    52,855
    wow, talk about touchy, and i thought we were bad.:rolleyes:
    rogerv likes this.
  20. Troy Heagy
    Troy Heagy Member
    1,218
    Honda's only the # 2 seller of hybrids in the world, so yeah, it's such a "failure". Since you made me see the light I took my 3 insights to the junkyard. You can celebrate with glee since you hated my car so damn mucb.
Thread Status:
