How to tell which wheel bearing?
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Aug 31, 2013.
Which bearing do these clues point to?
Poll closed Sep 7, 2013.
  1. Left front
    0 vote(s)
    0.0%
  2. Right front
    33.3%
  3. Left rear
    66.7%
  4. Right rear again (just don't make 'em like they used to)
    0 vote(s)
    0.0%
  5. Need more clues
    0 vote(s)
    0.0%
  1. ChapmanF
    15,450
    Ok, the first wheel bearing I changed on this car, 50,000 miles ago, was the right rear, and by the time I changed it there was no problem telling which one was bad; it was noisy and felt notchy just turning the hub by hand.
    I can tell by the sound (driving on pavement) I've got another one on the way out, but so far its not bad enough to pin it down by feel. (I've jacked up all four corners and spun/pushed/pulled/shook by hand, no difference I can feel.) It is getting gradually louder, and I'm sure I'll eventually be able to tell....
    Here's what I know so far:
    • sounds like a small propeller-driven Cessna or Piper, only not as loud
    • louder when taking right curves or cutting wheel to the right
    • softer when taking left curves or cutting wheel to the left
    • hub temps after several minutes on highway: front 50.3 and 50.8 C, RR 39.5 C, LR 43.3 C
    Anybody think you can call it from the info I've already got, or have another test I should try?
    Thanks,
    -Chap
  2. Patrick Wong
    18,200
    6,472
    If the bearing noise is evident at very low speed, can you have a helper drive the car in a circle while you are outside the car and attempt to determine which wheel the noise is coming from?
    It would be very hard to determine that a front bearing is bad via spinning by hand since you can't spin a front wheel very fast, with the differential components and the other wheel slowing things down...
  3. bwilson4web
    15,512
    Heat is the enemy so that would be my diagnosis.
    You may be able to find a shop that has a wheel spin, balancer. If so, they may be able to spin the wheels fast enough to get a good diagnosis.
    Another option is I remember seeing a multi-microphone system that puts at least four in different locations. For your purposes, I would get two 'cheap' mics and a stereo jack.
    Wire them up and 'duct tape' to areas near each wheel and run the experiment using something like AudaCity on a laptop to record the two channels. I suspect doing the rear wheels will quickly confirm the diagnosis but if not, relocate to the front.
    You might experiment with using ear buds as cheap microphones. The price is right and depending upon the sensitivity of your audio input, you may get usable levels.
    Now if you don't have a laptop handy, you might experiment with bud-go-bud wiring . . . the Alexander Graham Bell, first telephone approach.
  4. ChapmanF
    15,450
    Well, I finally knuckled down and repeated the human frequency counter trick from my earlier story. It just required finding a sufficiently cop-free stretch of road at midnight where I could drive at various wrong speeds swerving constantly left and right.
    As before, with the standard tire sizes, tweaking a standard tuner from a=440 down to roughly a=433 (down 28 cents, if that's how your tuner's marked) seems to be a good futz factor to make tuner pitches match by ear with Gen 1 hub noises at "nice" speeds in US MPH (30, 40, 45, 60, ...).
    In this case, the pitch at 30 MPH is g (second below middle c), with 40 and 45 naturally being c and d (below middle c). 60 of course makes g again, below middle c, but in that octave it's harder to pick out of road noise.
    The car's now wearing Defenders (they retired the Harmony line :( Defenders are louder) rated 905 revs per mile, so at 40 MPH they're doing 603 rev/min. The c below middle c (a=433) is about 129 Hz, or 7740/min, so this noise frequency is about 12.8 × wheel speed. Back when my right rear went, the factor was 10.8.
    I wonder whether a difference like that would mean it has to be a different size/configuration of bearing, or it could be accounted for even in an identical bearing depending on whether the inner or outer race has the chief damage.
    Hmm....
    -Chap
  5. Jeff F
    Jeff F Member
    111
    37
    London, Ontario
    2001 Prius
    The size/type of damage to the bearing wouldn't change the frequency, would it? I would think that any measure based on RPM would be independent of bearing size. I understand using this technique to differentiate between wheel/drivetrain issues vs. transmission as you did earlier, but after that it seems to me to be of limited use.
    Two hopefully constructive comments:
    1) Have you ruled out tire noise by rotating/changing tires? A damaged or defective tire could account for the noise you describe
    2) I'm all for early diagnosis and intervention, but this seems like it might be a case of waiting until further deterioration takes place. If it is the bearing it will degrade to the point where there is a clear temperature signature or you can detect the damage manually, as before. I did some general reading on this recently when my front bearing went bad in my Kia, and lived with the noise for a few months while making the definitive determination of the problem. It doesn't seem like something that is dangerous or harmful to live with in the short term. The damage doesn't spread beyond the bearing, and I don't get the sense that things suddenly sieze up or anything, though I could be wrong...
    Jeff
  6. ChapmanF
    15,450
    Well, I don't know - I honestly don't know. My line of work hasn't ever involved learning about bearing noises, or even learning what bodies of literature I'd even look in to learn about bearing noises. So I'm just experimenting by collecting the information about the noise, and at whatever time I finally manage to confirm where it's coming from, maybe I'll see in hindsight whether anything about the noise could have told me something. Maybe knowing that either way could save somebody else some time.
    I have been thinking about bearings though. You've got an inner race (say radius R), a ball/roller cage (with n rollers of radius r), and an outer race (R+2r). In our application we've fixed the outer race at 0 RPM and the inner race is doing the wheel RPM. The cage is loafing along in the same direction as the inner race but a lower RPM, which I think might be ½(wheel RPM)R/(R+r). Don't quote me yet. My scribbles are hard to read and were done late at night, I should recheck them. But it's gotta be something like that.
    Anyway, if there's an outer race defect the n balls are going to smack it with frequency n(cage revs/sec), and if there's an inner race defect, that'll be n(wheel revs/sec - cage revs/sec). Of course there could be multiple defects, and the sound I think I hear could be any harmonic of that, so there might be so many possible variations on the sound that it won't have any useful interpretation. But sometimes real life turns out to be more cooperative than it strictly has to be.
    At least this picture satisfies me about why the sound frequency (in both my cases so far) has been a non-integer multiple of wheel speed (I kind of expected the ball count to be an integer, but the radius dependence of the cage speed solves the mystery). I can imagine how the sound might be useful to distinguish front from rear if they are of different radii [edit: or have different numbers of balls]. (Unfortunately, I can also imagine how it could be different even for identical bearings depending on which race is gronkled.)
    If my problem turns out to be in front, maybe I'll be able to report the sound is possibly useful (two observations, one rear at 10.8x, one front at 12.8x, make of that what you will). If it turns out to be rear again, then maybe not as useful (but we will have learned that both 12.8x and 10.8x are possible sounds from the rear).
    Good thought. I haven't, and it wouldn't be that hard. Over the last month I've already had wheels off three times trying to see if I can feel the damage yet (still can't); might as well put 'em back on different corners and see what happens.
    I'm not putting my money on that though; I really do think a tire defect would sound at wheel speed or a harmonic of that, not some non-integer multiple.
    I hear you. My last bearing was going during a crazy time when I was making weekly 600-mile road trips and didn't even have time to try anything until several trips had gone by; nothing bad happened (though I could clearly feel the damage by the time I was able to get to it).
    Based on how I understand the construction, I think it would be very difficult for a front hub to leave the car, as long as the axle nut is secure; I think the stub shaft has a flange too wide to go through the knuckle. Things would certainly have to get spectacular before anything could part company.
    As far as I know, that's not quite as true of the rear; let the balls and races wear down enough to clear each other and there's not anything left holding the hub on. I'm sure I'll be able to catch this well before anything like that happens, but one does hear of others experiencing it [edit: general stories, I don't mean Prius specifically].
    Right now I'm not making regular long trips as I was then. I could still be called on one unexpectedly, though, and I'd prefer to have a new bearing first. Once I know which to order, I'd prefer to use one of the online dealerships for the discount, at least if it's the rear. (The front bearings are cheap, but the job's involved. The rear's a straightforward job but the hub/bearing assembly's a chunk of change that I'd rather not spend until I know that's the culprit.)
    I've ordered a multi-microphone listener thingy, should have it by next week. They cost too much but there was exactly one for sale used the other day so I snagged it. We'll see how much I can learn from that. Who knows, it might be back on the used market soon....
    -Chap
  7. ChapmanF
    15,450
    For this car, anyway. If you're in, say, (what appears to be) some rear-wheel-drive SUV, don't count on that:
    The video is spent more on closeups than big picture, and the geometries aren't obvious at first: it's the right front, leaving the vehicle pointed opposite the direction of the pavement marks, so I infer it must have at least 180'd in travel, though maybe there's another interpretation I'm not seeing.
    -Chap
  8. bwilson4web
    15,512
    Ah HA! Someone else who uses their Prius to buy 'tools' . . . toys for boys or treats for geeks!
  9. ChapmanF
    15,450
    Ssh! Hey, aren't you the same one who said
    ? Toys for geeks, pal.
    -Chap
    bwilson4web likes this.
  10. scotman27
    scotman27 Active Member
    735
    81
    PA
    2001 Prius
    you could try a stethoscope and spin each hub by hand to see if you hear anything noticeable. you would have to remove the drums or you could pop the little center caps off and try that way
  11. ChapmanF
    15,450
    BTDT. It's not reached the point where I can hear anything that way. Part of the problem is having the bearing unloaded. If I could, say, spin it while exerting a quarter ton of pressure, we might get somewhere. (I've even thought about jacking up a wheel, then setting it down on some kind of roller contraption to carry the weight and spinning it that way, but I'm betting the 4-channel listener will do the trick with less trouble.)
    -Chap
  12. scotman27
    735
    81
    PA
    2001 Prius
    is the listener thing wireless? i would hate to be running wires all over the car, makes for some intricate wiring so it dont get caught in the wheels or any other moving parts. ive never used one of those listener things, i have used a scope and im suprised at what those do. its going to be interesting to see how this listener thing does. if it works well i may have to invest in one myself down the road.
  13. ChapmanF
    15,450
    Yes and yes. The pickup elements are built into what look like cheap battery clamps so you can clamp them right onto something for direct mechanical sound conduction. I clamped them onto one of the caliper bolt heads on each front, and one of the hub-assembly-to-bracket bolts on each rear.
    The pickups come with maybe half a meter of wire that you can route to the wireless transmitter; there's one for each pickup, about the size of a deck of cards. Each transmitter contains magnets (would hold to steel parts, but didn't seem strong enough to stay stuck over rough road), a spring-loaded thing like a belt-buckle clip, and a slot for velcro straps (for the win!). So, yes it's wireless, and yes, you still get to intricately route wires anyway. :rolleyes:
    I strapped each transmitter to some part fixed to body rather than suspension, so they wouldn't get bounced as much. I routed the wires from pickups to transmitters alongside each wheel speed sensor cable, which is already cleverly routed to flex with the suspension and not get in anything's way. The setup comes with a bunch of velcro straps and a bunch of ordinary one-time-use nylon wire ties, but instead I ran the wire along the speed sensor harness with a bunch of these thingies, which I already had a bag of and find much quicker to use.
    The sound is very clear. You can listen to the sounds of brake linings against rotors, and hear exactly when the ECU's switch from regen to exclusively brake pressure just before a stop. You can hear shoes expand and retract. You can hear some bearing sounds, very faint on most of them. Not faint on my left front. No, sirree, not faint at all on the left front. I'm pretty sure I know where my problem bearing is.
    Interestingly, I get really none at all of the low, Cessna-like sound that's the only symptom naked ears hear inside the cabin. The pickup works in a whole different frequency range where the sound is more like dragging an anvil down the street. Quite horrible sounding. If I plugged the receiver into the car's aux in and turned the bass up and everything else down, I thought maybe I was picking up some of the lower sound, but only barely. The pickup presents a whole different aspect of the bearing sound.
    Most surprisingly of all, I get no expected correlation with IR temperature readings at the hub center (negative correlation, even). I popped the hub buttons out of the wheels so I could shoot straight at the axle shafts in front and hub centers in back, thinking that's probably where bearing heating would best show up. The left front, the bearing that sounds the worst by a country mile, in fact reads 2 to 3 K cooler than the right front, which sounds perfectly quiet and smooth.
    In the morning I might go swap a couple of the pickups and transmitters just to rule out anything funny like transmitter #1 somehow having way higher gain than the others. But barring anything weird like that, I'm pretty sure I've got my culprit.
    -Chap
  14. ChapmanF
    15,450
    Swapped and nope, nothing funny. LF bearing is definitely shot. Parts on order.
    For those keeping track, so far I've lost one rear bearing (which rumbled at a pitch 10.8× wheel speed) and one front (12.8×) ... make of that what you will.
    -Chap
  15. bwilson4web
    15,512
    So what do you think of the audio system? Is it a keeper?
  16. ChapmanF
    15,450
    Well, given that nothing else I had tried gave me a conclusive ID on which bearing was going, and this thing made it obvious about 3 seconds after being turned on, I'm gonna say it's pretty useful. (Perhaps the 12.8/10.8 pitch business will prove to be useful for distinguishing front from rear, if it turns out to hold for anybody else, but that still won't pin down one bearing.)
    Now, cobbling together a few microphone elements and some spring clamps and velcro wouldn't be that hard for somebody with a bit of time or some parts lying around. A small amp and speaker, or just a plug to connect to the car's aux in and play through the car amp. This setup just saved me the time of cobbling anything together, and offered for a used price, that worked for me.
    One of the applications mentioned in the instructions is to clamp the pickups onto fuel injectors. Apparently they distinctly go tinktinktinktinktink if they're clean, and thumpthumpthumpthumpthump if they need cleaning.
    -Chap
  17. Patrick Wong
    18,200
    6,472
    Did you take any photos showing how you attached the sensors and wireless transmitters to the vehicle? Thanks!
    scotman27 likes this.
  18. ChapmanF
    15,450
    I didn't, sorry. In front I clipped the pickups onto the big ol' heads of the upper caliper-to-knuckle mounting bolts, and routed the wires exactly along the wheel speed sensor wires with three or four clips right over to the inner fender wall, and hung the transmitters on velcro straps fed between the plastic engine undercover and the body at the rear bolt (which is pretty high up on the fender wall).
    On the rears I clipped the pickups to one of the four hub/bearing assembly mounting bolts, again feeding the wires right along the wheel sensor wires. On reaching the body, the sensor harnesses go through a rigid guide that's held by a couple screws, and I hung the transmitters by velcro from those guides.
    It was just a matter of looking closely to see where stuff wouldn't get in the way (remembering my Dad's oft-repeated "never get between something that moves and something that doesn't"). I spent a long time placing the stuff, removing each wheel in turn. It turned out when I was done that everything had ended up where I could reach it with the wheels on the ground, so it was much faster to take off (or put on again, should I ever need to).
    -Chap
  19. scotman27
    735
    81
    PA
    2001 Prius
    that would be cool to see. i wondered how small those sensors are if you can put them on an injector, they must be small
  20. bwilson4web
    15,512
    Interesting.
    Today I started our 2010 and once the engine started, set the parking brake and shifted into "N" to watch the ICE temperature and fuel consumption:
    • 30-40C -> 0.45 gal/hr
    • 40-50C -> 0.35 gal/hr (in this range I heard the transition from open to closed loop)
    • 50-60C -> 0.28 gal/hr
    • 60-70C -> 0.24 gal/hr
    But as I was sitting there, I heard what sounded like intermittent, breaking glass. Random, but distinct. I'm not after a diagnosis but I'm thinking a mechanics stethoscope might be in my future. Or maybe I'll try my home brewed cheap earbuds approach. <grins>
