How to test HV battery state of health on your Gen 2 (answer)
Discussion in 'Gen 2 Prius Technical Discussion' started by S Keith, Mar 14, 2016.
  1. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    Sounds good. I wouldn't regard #1 as necessary. The act of force charging has always resulted in a sufficiently warm engine, but you went at it different. The important thing is you got it fully charged.
    Yeah, I'll clarify that the ICE doesn't restart immediately at two bars. It sounds like you have a successful test.
    I have found the test fails at some point between 54 and 70°F. I'll add that clarification as well.
    uart likes this.
  2. S Keith
    799
    329
    AZ
    2003 Prius
    I ran the test with the car showing 54°F today, and the compressor ran inconsistently. I saw currents between 8 and 11A. It was probably just too cold when you tested it, and you did it correctly. Given that you captured techstream data, there's probably no reason to re-run the test. The current was lower than desired, but it's probably all that was available.
    I would go with the computed SoH and investigate grid charging ASAP.
    jjdemu likes this.
  3. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Ok thanks. It was approx 68 to 70F when I tested, and I left both front doors fully open so that it had to keep working hard. So I think my results should be at least somewhere near right. :)
  4. S Keith
    799
    329
    AZ
    2003 Prius
    I agree. I'm checking the hourly forecast to try and hit 60-65°F. I'm thinking the limit is going to be somewhere around 65°F as that's the lowest specific temperature that can be set.
  5. Hokie-Dave
    Hokie-Dave Member
    161
    Manassas, VA
    I'm thinking of trying this test this weekend on my '07 just to get an idea of the battery health. I see the discussion on what temps the A/C draws enough of a load and was wondering about using the front defroster on high instead of just A/C cool? I know in my other cars, the A/C compressor runs when the defroster is turned on, does the Prius work the same way?
  6. S Keith
    799
    329
    AZ
    2003 Prius
    I couldn't find anything that worked this morning at 54°F. If you set to heat, the demand will run the ICE. Setting to a neutral/cold temp with front defroster pulled about the same as partial A/C, and neither were consistent.
    I think a no-A/C version can be had with about 6A, which is still a reasonable current with which to test. Unfortunately, that's going to push the test close to 30 minutes.
  7. valde3
    valde3 Senior Member
    2,002
    747
    Finland
    Testing at 1c or 33F I could only get the current up to 5.3A. Without using heater (that would take heat away from engine and make it start). Or using seat heaters (which you don’t probably have). AC being on or off won’t make any difference as it can’t cool the air any more.
    5.3A is significant difference from 6A it creates about 12% differences in results.
    What kind of current draw do you get without AC?
  8. nicholas_k
    nicholas_k New Member
    Kansas City, MO
    Your approach seems very logical, but can you think of any possible safety issues to address before attempting this process?
    I don't think you mean it literally, but as someone who has a tendency to take things literally, it always makes me nervous when I read phrases like "Parking brake on as hard as you can press it" and "smash and hold brake, in 'D'"
    What are the chances of damaging our car from pushing the brakes too hard? Most things have a limit to how much stress they can take before they break.
  9. S Keith
    799
    329
    AZ
    2003 Prius
    Zero.
  10. jjdemu
    jjdemu Junior Member
    39
    IL
    Just order the grid charger and some gloves, will post results after I install it. I redid the test on a 73 degree day and it has higher current then the last test. Figure this way we will have a before and after the grid charger.
  11. S Keith
    799
    329
    AZ
    2003 Prius
    This is a perfect example of how the 0.2V deltaV rule does not apply. You were barely over 0.2V at the very end of the discharge. This is very good news as I believe these results represent the best potential for recovery through grid charge/discharge reconditioning.
    Your computed capacity is 1,090mAh, which is 40% SoH.
    Note the red highlighted region representing the 55-65% SoC range, where the car spends a lot of its time. You're subject to a lot of voltage fluctuation in that zone indicating a lot of voltage depression.
    Your test lasted 4.72 minutes. 4.72 * 9.5% = 44.8% SoH.
    I like that accuracy, but I'm biased.
    I'm extremely excited to see your results given your high mileage.
    Please keep us posted.
    jjdemu likes this.
  12. S Keith
    799
    329
    AZ
    2003 Prius
    Given the age and mileage, I would encourage you to take your time with multiple charge/discharge cycles. Given the uniformity of your block voltage response, I recommend the following for emphasis on both expediency and maximum benefit:
    1. Force charge in car to 80% SoC
    2. Grid charge for 12 hours (this fills in the last 20% and will balance individual cells).
    3. Conduct discharge test to 40% SoC
    4. Discharge to 201V w/2X 200W max.
    5. Discharge to 135V w/2X 25W max
    6. Grid charge for 4 hours (or more until 220V min)
    7. 12V reset and idle charge in car until termination.
    8. force charge in car to 80% SoC
    9. Grid charge for 8 hours (Cells have been mostly bottom-balanced, less grid charging is necessary).
    10. Conduct discharge test to 40% SoC
    11. Discharge to 185V w/2X 200W max
    12. Discharge to 84V w/2X 25W max
    13. Grid charge for 4 hours (or more until 220V min)
    14. 12V reset and idle charge in car until termination.
    15. Force charge in car to 80% SoC
    16. Grid charge for 8 hours
    17. Drive it for a week
    18. Repeat discharge test
    NOTE: you will do FINE if you use the HA instructions. The above is what I would do if it were MY car with the goal of doing two conservative discharges to 0.8V/cell and 0.5V/cell successively while saving as much time as possible. Given the age/mileage on your battery, I feel the initial discharge should be to 0.8V/cell with 25W max bulbs when under 1.2V/cell.
    Jeff may disagree with the above. If so, follow his lead! :)
    uart and jjdemu like this.
  13. jjdemu
    39
    IL
    Great information and was going to ask if you had any suggestions about doing the test compared to what was on the website. Thanks for beating me to the punch
    blauweaaf likes this.
  14. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    I tested mine today. 2008 93k. 70 deg.
    5 min 37 sec. aka 5.61aka 53%
    First time I had fog lights on.oops. And the parking lot I was in wasn't really level,do you think level should be a consideration??I will retry tomorrow. I was a bit surprised since wife gets typically 45mpg,with no regard to hybrid,and I can get 50 to 52 on my commute to work if I try. after the first test I could not get the eighth bar to go green... after several attempts of force charging, downhill braking, etc. It would not go green. How many times can we repeat this, I didn't want to burn up the cvt?? After 3 attempts to force charge for 2 to 3min already at bar 7...I figured better not stand on the gas and brake for too long. I did just change my ATF last week. Would that make any difference?
    #34 lextoy, Apr 25, 2016
  15. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    Also I am curious, any benefit to the hv from force charging, and then doing your test down to purple bars. Could it be even slightly beneficial since my car typically only ever sees green and blue bars? I also wonder if there would be some way to manipulate the charging software in the prius to do what the external installation for charging/discharging does to recondition the battery. Force the prius system to top reset and bottom reset once in a while.
  16. S Keith
    799
    329
    AZ
    2003 Prius
    Sometimes it's hard to get to the eighth bar. At that point, your're probably at 75%+ SoC. SoC is an approximation based on many factors, and it lags reality. Another parameter may have been limiting the charge, such as the Max block V in relation to the charge current. Fog lights are fine. Level doesn't matter. ATF fluid change doesn't matter. Everything you did is conservative thus, your battery is likely no worse than the computed 53%. I would expect that your car is actually in the high 50s/low 60s. The car can perform very well even at that SoH. I have found it's around 40% where problems start to show up (accelerated SoC gauge movement, reduced mileage). Commuting mileage that involves a lot of non-stop freeway driving hardly uses the hybrid system at all, so it's a poor indicator. In-town typical stop and go is the best measure. 45mpg without conservative driving is pretty good.
    No benefit whatsoever. Benefits occur when you take the battery SoC outside the car's operating range.
    The behavior you describe has been documented on the Gen1 where it forced charged to near 100% and discharge to the vicinity of 20%; however, I do not have any knowledge of the Gen2 exhibiting this behavior.
  17. jjdemu
    39
    IL
    Finished up the second grid charge earlier and doing the second set of discharging. The grid charger was pretty simple to install with no problems. Will post results of discharge test on next warmer day, probably Wednesday or Friday.
  18. S Keith
    799
    329
    AZ
    2003 Prius
    If you can capture it with Techstream, and upload it... that would be great.
  19. Former Member 68813
    3,524
    983
    US
    cool thread! how much of this applies to the 3rd gen?
  20. S Keith
    799
    329
    AZ
    2003 Prius
    I'm still working on that one. I haven't had a chance to test a Gen3 yet. From what I hear, one can only force charge to 60% SoC
    Former Member 68813 likes this.
