How to test hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kkeane, May 17, 2015.
  1. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    The cleaning is all pretty straight forward, a clean cloth and remove the sensor and clean throughly. I did this yearly.
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Sounds like the intake manifold and the MAF sensor.
    Raytheeagle likes this.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    More likely it's the throttle body and MAF sensor. And the sensor should not cleaned with a cloth--follow directions on the can of MAF cleaner.
  4. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Correct answer.
  5. OutDoorsKC
    OutDoorsKC New Member
    Houston, Texas
    Thank you bisco for your quick reply! I think your right. I'm planning to start the rebalance process this weekend on the battery pack and replace any modules that turn out bad or close to it.
    - Scott
  6. bisco
    52,776
    all the best!(y)
