How to test the solar panel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by evebill8, Nov 22, 2011.
  1. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    I am trying to test if the solar panel is working. At first, I turn the power to ON mode, set the temperature to 68, press the ventilation button, then, turn off the power. I left the prius under the sun for few hours, but it still hot inside. Would anyone tell me how to test it?
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    You've followed the correct procedure, though I'm not sure the temp setting matters. After shutting off the car for five or ten minutes (can't remember the time), the fan will start up if there is sufficient sunlight falling on it (thin, skuzzy clouds are ok, but not big fluffies). Inside the car, you'll hear some "flatulence" as the computer opens the air vent, or whatever it's doing, and you'll feel the breeze. Outside the car, you can hear the inrushing air at the base of the windshield on the pax side. The sound happens at temps down to the 50s, though the fan may not run in cooler temps (it is supposed to check for that).
    Double check the position of the switch - on vs off is only one or two mm.
    But it may still be hot inside when all is said and done - it's not running the AC. But you can use the AC button on your fob to get three minutes of cooling before entering the car if you have sufficient charge on your traction battery before you park.
    More detailed testing would probably require a trip to the dealer.
  3. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Thanks! Just make sure I don't misunderstand what is ON mode. I press the power button once, the navigation is on. I press the power button one more time, the digital panel is on, and that is ON mode, right?
  4. Tideland Prius
    16,658
    Correct. To clarify, we say IG-ON to differentiate it from "Ready" (which is when the car is actually on and running). You could try doing it with the car in Ready instead of IG-ON. Same procedure but in Ready mode.
    Also, note that the interior temperature has to be warm enough otherwise it won't run because it doesn't want to vent out the cooler air (e.g. if you had the A/C running before you shut off the car. That's why there's a 10 minute delay at the minimum).
  5. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Thank you very much!
  6. rdalemercer
    rdalemercer New Member
    KY
    evebill8 - additionally - you need to make sure the the SOLAR ROOF switch is set to "on" - as Buzzhead also commented.
    There is a switch on the lower panel (to the LEFT of your steering wheel) that has a push-on / push-off switch for the solar panel. There is only a "very slight" difference between on and off so you may need to push it several times to make sure that it is pushed in (on). There are no indicator lights or any other way to tell that the switch is engaged and the solor roof panels are "on".
    Following that, you should be able to hear the fan running after about 5~8 minutes in the direct sunlight. I'm not sure if the ambient air temp makes a difference as I turn mine off when its "cool" outside.
  7. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    There isn't actually any procedure. All I've ever done is push the solar-ventilation button. That's it. The Prius doesn't even need to be on and there's nothing related to the AC system that you must do. It just works.
    It works in surprisingly cold temperatures too. On several cold spring days I've waited out in the Prius listening to the solar cycling while the girls are in stores shopping. It's quite entertaining, as well as making the vehicle itself comfortable.
    I'm really going to miss that... when I get my plug-in Prius this spring. Oh well. That will be a reminder just how effective it really was. There's a big difference between hot & warm. Having that modest air circulation took the edge off.
  8. Tideland Prius
    16,658
    True but the car needs to be on when the SPVS button is pushed in. The SPVS will not work if you push the button in while the car is off.
    That's true. It still works in cooler temps.
  9. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    I tested the solar panel yesterday. I used scotch tape to secure a tissue paper by the vent. I stood outside and waited for 10 minutes. I saw the tissue paper was waving slightly, but I could not hear anything from outside. After about 2 seconds, the tissue paper stopped waving. Then, it waved again after few minutes. When I popped in the car, the interior is still warmer than I expect.
  10. Buzzhead
    151
    59
    Chelmsford, MA
    Try again while sitting in the car. At full sun (you have that there, right?:)) it seems to blow at about the equivalent of two or three bars on the fan scale. If you're not getting that, it may be time for a trip to the dealer.
  11. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    can I do it when the windows are open right?
  12. Tideland Prius
    16,658
    Sure but that'll defeat the purpose since open windows will keep the interior cooler so the SPVS may not need to run (I assume you mean fully open and not just a crack, right?)
    Yes it will run as necessary and with whatever available solar power it can store. If you're expecting an A/C-cooled interior temperature, you're going to be sorely disappointed; that will never happen.
    All it does is vent out the hot air that builds up inside the car and bring in the (relatively) cooler outside air. Compare two Prii side-by-side in the middle of July and tell me that the solar-equipped car isn't noticeably cooler. Our other Prius is a 2005 w/ beige interior and it was much hotter than my dark grey interior 2010.
  13. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    Yes, it is about the 2 to 3 bars of the fan scale. However, it only lasts 2 seconds, then, spins again after 1 minute, and so on. Could that be the sun light is not enough? I am sure it will cool down the interior if the fan can spin longer.
  14. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Let me get this straight. You could not sit in the car for 10 minutes.
    In San Jose.
    In November.
    Really?
    Just like any other vehicle, tint and a windshield reflector really help but it will never keep it at ambient temp due to the greenhouse effect from all those windows.
  15. evebill8
    evebill8 Member
    139
    16
    San Jose, CA
    I did this time. I was in the car.
  16. Tideland Prius
    16,658
    That's the way it's supposed to work. It's November so the angle of the sun is lower and the temperature is cooler. Wait til July or remind me to make a video next summer.
