How to tighten rear view mirror?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius92, Jun 23, 2025.
  1. Prius92
    Prius92 Active Member
    595
    122
    Iowa
    Usually there is a visible screw, but I've looked all over and can't find one.
  2. Tombukt2
    Tombukt2 Senior Member
    13,803
    2,504
    Durham NC
    I don't think the base flip mirror has a screw but I look in an homelink might. I've both here. I thot I changed 1 flip mirror just because of this . In one. I also found aftermarket day night mirror that has 2 lights firing down very convenient. I really like that mirror .
  3. Prius92
    595
    122
    Iowa
    I took the mirror off and there is no screw, not the fancy auto-dim home link mirror.
    I've never had a mirror "wear out" but it's loose where it attaches to the metal plate on the windshield, the metal plate itself is not loose.
  4. Tombukt2
    13,803
    2,504
    Durham NC
    Yes it's a spring clip you released w small x driver I don't think ya can adjust the spring pressure .
