How to Turn off All Heat and Cold A/C?
Discussion in 'Prius c Main Forum' started by highroller, Mar 4, 2014.
  1. highroller
    highroller Junior Member
    79
    I have a Prius C 2013. This may sound like a stupid question, but it is not. In my old car, I could turn off all heat and cold A/C, and it can guarantee that heater and a/c compressor are not running. But with Prius, I turned off Auto, heat and cold A/C, and I can still feel warm air coming out the the vent when it is running on the highway. Why? How to solve it?
    I am just trying to suck air from outside into the cabin without wasting fuel on heat or cold a/c. I am trying to get higher MPG.
    52,825
    welcome to priuschat, did you turn heat to 'low'?
  3. firstrival
    firstrival Member
    102
    Press the "Off" button?
  4. highroller
    79
    Yes, I already pressed the off button. No use. I think Off is for fan. But I can still feel heat air being pushed into the cabin by outside air when it is on highway.
  5. highroller
    79
    Where is Low? When I turn the Temperature dial, it shows only temperature number. No way to be off? just low?
  6. bisco
    52,825
    i don't have a c, but on the liftback, when you turn down the temp, the lowest temp number is 65, and the next setting down says 'low'. it doesn't go any lower, so that is off.
  7. bisco
    52,825
    yes, off is for fan only, temp has to be lowered as far as possible before hitting off.
  8. highroller
    79
    Lol, low is off... Toyota needs to work on their use of English term.
  9. bisco
    52,825
    yup, been like that for a long time, not likely to change.:cool:
  10. bisco
    52,825
    i have found that fresh air tends to be warmer than ambient, perhaps warmed by the engine compartment?
  11. highroller
    79
    Now is winter. So what about Summer? If I want everything to be off in Summer, do I still keep temperature to "Low"? Is it going to trigger cold air with A/C off in summer?
  12. bisco
    52,825
    no, if the a/c button is off, you can have fresh air in summer with temp on low. just don't use 'auto', it's a game changer.
  13. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    And just one more little point of clarification:
    You can not ever turn the air circulation completely OFF; that is a safety feature having to do
    with maintaining a tiny positive cabin pressure to help keep exhaust gasses out.
    Regarding the initial question:
    Whatever heat is leaking into the remaining incoming air is just that, a leak.
    If your concern is with fuel economy, rest assured that the car is NOT adding that heat on purpose and will NOT make the engine run to maintain it.
    Every car/truck I've had in the last 10 years or so wasn't able to completely turn off the heat when you want only fresh air.
  14. I know why this is happening.
    And I had this exact same question before (can't find the post) but here you go:
    After you have turned everything off, press the button with your temperature controls that re-circulates the air.
    This will turn off all the drafts, hot and cold.
    lostangeles and Domovoi like this.
  15. highroller
    79
    I think that the car somehow remember the temperature I set before I turned everything off 2 days ago. I don't think this is the heat leaked from the engine or other mechanic of car because the heat is quite strong.
  16. akaryanreynolds
    akaryanreynolds Junior Member
    los angeles
    Nailed it (y)
  17. highroller
    79
    No, because I want fresh air from outside.
  18. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Just a note for summer, the A/C that is keeping you cool is also keeping your batteries cool. do not skimp on A/C.
    (This will be more important in AZ than in AK)
  19. Then it sounds like you'll have to keep that re-circulation button off.
  20. Easy Rider
    982
    210
    N. Central Florida
    And I think you are wrong.
    Years ago, they used to regulate the heat by shutting a valve in the water line to the heater core.
    As long as the valve worked, that assured you of no stray heat.
    Then.....about 30 years ago or so, probably as a cost cutting measure, they left out that valve and the heater core is HOT all the time.......and the temperature is regulated by how much air is allowed to flow over it and into the cabin.
    The problem with that is that the air dampers often don't close completely and often allow a bit of HOT air to flow even when the door is closed.
    So.......if you restart the car after it is hot and was off only a short time, the first air coming though often is pretty hot, because of the above mentioned design and because the air inlet by the windshield is always BLACK, taking only a very little sun to make that first gulp of air pretty warm.
    Having said all of that, if yours doesn't cool down after a few minutes of having the fresh air on and the climate control off, and assuming you are moving at a fair speed, you might want to ask your dealer or mechanic to check the damper doors.
