How to turn on radio?
Discussion in 'Gen 2 Prius Audio and Electronics' started by Mary Snyder, Dec 2, 2006.
  1. Mary Snyder
    Mary Snyder New Member
    132
    Can anyone here tell me how to turn on the radio? I read the manual but there is no simple answer.
    Mary
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(Masnyd @ Dec 2 2006, 03:31 PM) [snapback]356785[/snapback]</div>
    There is a Power button "PWR" on the dashboard to the right of the shift lever and the Park button. Alternatively, you can do it by pushing the "MODE" button on the steering wheel.
  3. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    You can also hit the "FM" button if you wanted to listen to FM radio (or "AM" button for AM radio).
  4. Mary Snyder
    132
    <div class='quotetop'>QUOTE(Masnyd @ Dec 2 2006, 07:31 PM) [snapback]356785[/snapback]</div>
    Thanks so much AmeriPrius. I appreciate your kindnesss.
    Mar y
    <div class='quotetop'>QUOTE(IsrAmeriPrius @ Dec 2 2006, 07:49 PM) [snapback]356790[/snapback]</div>
    Thanks so much AmeriPrius. I needed the help and do appreciate your kindness.
    Sincerely,
    Mary
    <div class='quotetop'>QUOTE(Stev0 @ Dec 2 2006, 08:22 PM) [snapback]356794[/snapback]</div>
    Thanks StevO for your clear answer. I couldn't find that anywhere in the manual.
    Thanks so much.
    Mary
  5. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    This is a "goof" right?
  6. Tideland Prius
    16,445
    <div class='quotetop'>QUOTE(J.Wilkie @ Dec 5 2006, 01:12 PM) [snapback]358124[/snapback]</div>
    Well, most car stereos use the volume button as the power button too.
  7. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 5 2006, 02:24 PM) [snapback]358149[/snapback]</div>
    And on the Prius you can actually press the Volume control, but it just drops out of sight. :)
  8. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(Masnyd @ Dec 2 2006, 06:31 PM) [snapback]356785[/snapback]</div>
    Inserting a CD will also power it up.
  9. scoot
    scoot Member
    125
    I find that cars with steering wheel controls use the volume up/down buttons as "un-mute" but not power cycle.
  10. Mary Snyder
    132
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 5 2006, 06:24 PM) [snapback]358149[/snapback]</div>
    No not a foof at all. I seriously could not turn on the radio. but thanks for the help.
    Mary
