How to verify OEM spark plug compatibility Prius Gen3
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatorback, Dec 6, 2025.
  1. ASRDogman
    ASRDogman Senior Member
    8,055
    4,083
    Yes, that's the denso one. Which is good also.
    I'll have to find the one from illinois.... He shows the parts, like the oil filter.
    The cheap chinese copy one is soft and flexable. The Toyota one is a lot firmer, and solid.
  2. ASRDogman
    8,055
    4,083
    You are just kidding, right? Have you never had to fight out a small seized bolt????
    I know bosch coats the threads on there plugs... Not sure about anyone else.
  3. ASRDogman
    8,055
    4,083
    Found it!
    Counterfeit Toyota Parts Video:
    gatorback likes this.
  4. Patrick Wong
    18,210
    6,517
    Well, the spark plug is supposed to be tightened only to 15 ft lb and the spark plug hex is a 14 mm size, so you are able to exert pretty good torque when removing it. With my limited experience removing the 2015's spark plugs once, it didn't seem that removal would generally be a big issue with the rubber seal on the spark coil keeping the spark plug tube clean and free of corrosion.
    Compare to Classic and 2G where the spark plug is a little larger in shell size, and I recall occasions where I was wondering if a plug was binding while trying to remove it.
  5. ASRDogman
    8,055
    4,083
    If it feel tight, I unscrew it like you SHOULD use a tap. Turn a 1/2 turn, then turn back 1/4 turn.
    Usually the last few threads have carbon build up, that's why it's tight.
    Patrick Wong and Mendel Leisk like this.
  6. indel
    indel Member
    283
    89
    Northwest Indiana
    Should the plugs be changed when the engine is hot or cold?
  7. Patrick Wong
    18,210
    6,517
    Cold
    Brian1954 and indel like this.
