How unfamiliar technology might have doomed these two women,
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Feb 22, 2020.
  1. ChapmanF
    17,933
    I do that all the time. It parks. It's not like luck or anything, it's programmed to do so, the owner's manual says it does, and it does.
    I had that feature in my '72 Dodge Colt (a Mitsubishi Galant by any other name...), only it didn't come with guys. I would try to scout out sort of raised places in a parking lot, so I could get it going easier.
    There was one really hot day where I had parked in a little dip. In a gravel lot. Did eventually get it started, then had to wring out my shirt.
  2. Prius Maximus
    Prius Maximus Senior Member
    955
    809
    Northeastern IL
    You never saw "The Enemy Below"? Great movie. That's where I learned "Torpedos - LOS!".
    Curt Jurgens, Theodore Bikel, Robert Mitchum.
    The Star Trek (Original Series) episode where they chased the Romulans to the neutral zone was a direct ripoff of that movie.
    WilDavis likes this.
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,426
    2,393
    Taylors, SC
    Die GlĂ¼ckliche Zeit und der Unternehman Paukenschlag.
  4. 3PriusMike
    3,097
    2,419
    Silicon Valley
    New technology can be better.
    In the Tesla, if you do not put it into "park" but you open the door or just remove your seat belt and lean to grab something (slightly unweighting the seat sensor) the car automatically goes into park with the parking brake applied. It does this with a beep and an on-screen error message.
    Also, although you can explicitly apply the parking brake, it always is applied when you go into park and disengaged when you go to drive or reverse.
    If you have one pedal driving enabled (which is the most efficient) you always must press the accelerator in order to make the car go when in gear even for low speed...i.e. there is no creep which could cause a flustered driver to try and step on the brake but accidentally step on the accelerator.
    Mike
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …no, but I think the best submariner film of all time, has to be "Das Boot" (…IMNSHO the best war-film ever made!) :);)
  6. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
  7. WilDavis
    2,493
    2,155
    49
    …or even "Hals- und Beinbruch!"
  8. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
  9. ETC(SS)
    7,094
    Balance of Terror - Wikipedia
    Roddenberry was a WWII Army pilot, and Star Trek was filmed during the hottest parts of the Cold War. It's not at all surprising that he based this episode off of that excellent movie.
    BOTH are well worth your time, even if you're not a fan of either genre.
    "Most famous submarine action?"
    I respectfully disagree.
    In the US it would probably be the H. L. Hunley getting wartime tonnage down in Charleston.
    Fun Fact:
    Hunley killed more rebs in that action (8) than U.S. Navy sailors (5)....and 13 rebels died inside the sub before the famous attack in Charleston Harbor.
    I would presume also that the RMS Lusitania getting knocked off by U-20 is also a more well known submarine/U-boat action.
    (Recommended reading: Dead Wake, by Erik Larson)
    Otherwise, most Americans are dimly aware that there were two World Wars, and that convoys and submarine attacks were somewhat featured in both.
    I can report that this was a favorite among US Navy Submariners, where we unreservedly rooted for the wrong side.
    There's a 6-hour version of Das Boot from the full-length TV series available available on Amazon (as is everything else in the world....)
    if you wanna take a......'deeper dive' into the work.
    @ the original subject.....
    "Knobology" is important.
    Sometimes: Vital.
    Engineers go to great lengths to make cars somewhat intuitive, but even in carbureted engine, manual-shift, crank window horseless buggies......people fail to read manuals, mash the wrong pedal, drive drunk or distracted......etc.
    #49 ETC(SS), Feb 25, 2020
  10. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    Again, this is the American point of view. In Europe, the achievement of the U9, a kerosene fueled submarine, changed the entire scope of the war at sea and marine warfare ever since.
    That and the Dardanelles Campaign led to the failure of Winston Churchill, who was not redeemed until World War II.
  11. ETC(SS)
    7,094
    ...and Europe has been struggling to remain relevant at sea and in marine warfare......ever since.
    H.L. Hunley, Germany's K9, XXI types and IJN's I-400 all used ground-breaking tech...and all served on the losing side.....;)
  12. El Dobro
    El Dobro A Member
    7,079
    3,259
    ETC(SS), WilDavis and Prodigyplace like this.
  13. Georgina Rudkus
    3,426
    2,393
    Taylors, SC
    The other event that really changed naval warfare was the ill intended Washington Naval Treaty of 1925 that limited capital ships; mainly battleships.
    The Japanese had battleships under construction when the treaty was signed.
    Instead, we all know what happened at Pearl Harbor, Force Z and Midway. The Japanese had built aircraft carriers from those hulls.
  14. ETC(SS)
    7,094
    Concur.
    Unfortunately....arms treaties are usually very flawed instruments....something we never seem to stop learning.
    We also lost a lot of sailors aboard "treaty cruisers" in WWII...but it turned out OK in the end.
    Our own Lady Lex (CV-2) and Sister Sara (CV-3) were similarly built from "battlecruiser" hulls....and even though Sara survived the war, most of the early CVs were lost in action, since they were (and are) easy mission kills......thick hide notwithstanding.
    ....IF you can get TO them. ;)
    The most important contribution these hulls made to both the IJN and the USN are the thousands of sailors who were exquisitely trained (or...not so much...) in the years that led up to the shooting part of the war.
    One of the very best books I've ever read about life on a WWII bird-farm (from the IJN's point of view) is Shattered Sword....by Jonathan Parshall.
    Phenomenal work!!
  15. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    How did this thread morph into a discussion about warfare and historical submarine technology?
  16. 3PriusMike
    3,097
    2,419
    Silicon Valley
    Cars on a ferry trying to mimic the capabilities of a submarine by operator error.
    Mike
  17. Trollbait
    12,466
    Submarines came up when a photo of an old one's controls was posted as an example for most confusing.
  18. ETC(SS)
    7,094
  19. Trollbait
    12,466
    Reminds me.
    Get rat traps.
  20. Prius Maximus
    955
    809
    Northeastern IL
    Most confusing? Try this one...
    Trollbait likes this.
