How was this car driving HV Battery problem
Discussion in 'Generation 1 Prius Discussion' started by Sharnold, Feb 27, 2019.
  1. Sharnold
    Sharnold Active Member
    400
    126
    Alabama
    2003 Toyota Prius HV battery was swelled on the main cover has exploded cells and was still driving even with the P0A80. The car came in with the dreaded triangle of death and after inspection you could hear a sizzling noise coming from the HV I pulled the main switch pulled the plastic covers and there it was swelled and sizzling needless to say its toast..... will post better pictures when I get back to the garage
    Data Daedalus likes this.
  2. Sharnold
    400
    126
    Alabama
    I have a video how do I post it?
  3. Mendel Leisk
    42,055
    If you can manage to register on YouTube and uploaded there, then you can provide a link here.
    Data Daedalus and Sharnold like this.
  4. Sharnold
    400
    126
    Alabama
  5. ASRDogman
    ASRDogman Senior Member
    7,901
    4,018
    Just use JB Weld to put it back together. You'll be fine! :)
    :whistle:
    Sharnold likes this.
  6. Sharnold
    400
    126
    Alabama
    A little JB weld some epoxy and duct tape that bad boy would run like a scalded ape
    #6 Sharnold, Feb 27, 2019
    ASRDogman likes this.
  7. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I'd like two eggs sunny-side-up to go with that sizziling bacon.
    Man, that's crazy!!!! :confused:
  8. ePRIU$
    ePRIU$ Junior Member
    35
    Did you find out what was the cause? it would help other owners to prevent this happens to their HV, thanks.
  9. Sharnold
    400
    126
    Alabama
    I will be able to let you know the cause this evening with pictures as I just picked up another replacement battery from the parts lot
    #9 Sharnold, Feb 27, 2019
  10. Sharnold
    400
    126
    Alabama
    Four cells are completely blown fan was full of trash and dog hair....... now the main reason this is the customer's sons car. When it started blowing the dreadful triangle of doom the owners son had it scanned and decided to take matters in his own hands due to low voltage on the HV so he started to crank the car put in drive hold the brake and depress the accelerator charging the HV......... ending result overcharged cells........ do not by any means do this cost to fix $1600 20190227_182803.jpg 20190227_182810.jpg 20190227_182814.jpg 20190227_182803.jpg
  11. Sharnold
    400
    126
    Alabama
    Correction and my apologies this is a 2005 prius not a 2003
