HOWTO: Resetting the Oil Maintenance Required indicator
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mr. Bill, Oct 5, 2009.
  1. Jordao
    Jordao Junior Member
    Puerto Morelos, QROO, Mexico
    Depends on the type of conditions you drive in (dusty, cold, cruddy - what part of Canada, that is) I think their recommendation is 3 to 5 thousand miles. I think the light comes on every 5K. The best investment you can make in your car's engine longevity is regular oil changes. Do it yourself, it'll cost under $10 (both Canadian or US... except for your taxes... yikes.)
  2. DavidA
    2,349
    1,825
    Chicago western burbs
    You can if you want to. :D
    The point of this thread is how to turn the nag reminder off completely so it won't display every time you turn the car on. The 2010 GenIII was originally programmed to display the nag screen beginning about 5,000 miles following a dealer oil change reset. Since the current oil change interval is now 10,000 miles, and with apparently no way to reset the car's firmware to a 10,000 mile reminder interval, drivers won't go nutz seeing the da##ned nag thing 5,000 miles prematurely.
    I had the 15K oil change just today. I won't have the dealer do another change until 25K miles, and by then the warranty will have expired. I use 0W20 synth.
  3. J5A
    J5A Active Member
    592
    83
    Severna Park, MD
    Thanks Mr. Bill!
  4. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    It takes up too much ink?
  5. rctech
    rctech Junior Member
    46
    Chicago
    I know old post, but jut some observations.
    No the "Trip A" does not get reset to zero.
    I also note that you do not have to actually start the car (i.e. foot can be off the brake).
    From TripA mode and Off... Just tapping the START button twice (like turning on accessory mode),
    while holding down the mph/km button is good enuf to initiate the zeroing.
    rich
    IronWaffle likes this.
  6. Dale Osterling
    Dale Osterling New Member
    thank you, it worked. Like others, I put a copy in my glove compartment. Dale
  7. jfrandson
    jfrandson New Member
    Minneapolis
    Hey everyone. So far the dealer is a little stymied by this one, so just wondering if anyone has encountered this problem:
    I brought my 2013 (series four) prius with nav into the dealer and had the maint done. They were unable to reset the service required indicator (following the typical procedure below). They told me to come back and have them hook it up to the computer to figure out what was wrong. When I brought it back, they tried to reset it again and suddenly it worked, without doing anything differently. Fast forward, I just had maintenance again. Again they cannot get the maint required indicator to turn off. So weird. Anyone heard of anything like this.
    Jared.
  8. compac
    compac PSU, Metallic Blue Ribbon
    52
    VA, Blue Ridge mtns
    I always have the reg odometer showing when doing the Oil mait required reset, and follow the above info with door closed pwr off foot on break.
    , ... locate the MPH/Kilometers button on the dashboard. Press and hold down and then restart the car by pushing the power on button (hold both buttons down at the same time - when the scale is re-set, let go of both buttons)
  9. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    You forgot the steps to raise your left front paw, tap you right rear paw, whistle Dixie, and blink 3 times.
    Thanks as this came in handy on a trip.
  10. Brenda A
    Brenda A New Member
    Verona, WI
    My MAINT REQD light will not shut off, despite using the technique/process outlined in Mr. Bill's instruction above.
    I took my Prius to Firestone for an oil change and they weren't able to get it to shut off either.
    Perhaps I need to check the oil level next? I've made multiple attempts to follow the owners manual instructions and Mr. Bill's instructions.
    Something is amiss.... any help or suggestions would be appreciated!!! This is my 3rd prius...never had this come up before.
  11. bisco
    52,914
    welcome! you're in the gen III thread with a 2009, do you have the correct o/m? and yes, checking the oil level is always a good idea, although low oil doesn't throw the maint. req'd message.
    one thing someone mentioned, there is a mait. menu in the mfd which has a calendar that can be set. i think it brings up a different reminder than the programmed one though.
  12. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    For your car (09 Prius) you have to do this.
    Press start button until car turns the ignition on
    Make sure the odometer displays "ODO" NOT TRIP
    Press and hold the ODO trip reset button in
    press start button until car turns off
    press start button until car turns back to ON
    Hold the ODO button in until all the flashing lines on the odometer go away and the mileage returns and the maint reset light stops flashing
    1) Confirm that your Odometer is set to "odometer" (ie. NOT to Trip A or Trip B)
    2) Start with the car off.
    3) Press and hold the ODO button...don't release it until the process is complete
    4) put the car in either Ignition On (2 presses of power button without pressing the brake) or Ready (one push with foot on brake).
    5) Watch the area where the odometer reading shows up...it will show zeros that become dashes, then flashes to the regular odometer reading. Once you see that you can release the odo button and turn off the car.
    This will reset the maint req. light which will flash on briefly in 4500 miles and come on and stay on in 5000 miles.
  13. Rick Knowlton
    Rick Knowlton New Member
    Central PA
    I think this was already posted somewhere, but it couldn't hurt to reiterate it.
    Just did my 2015 P 3 @ 3700 miles, Mr. Bills tip worked perfect, but just wanted to add i did not have to start the car while holding down the MPH-Km/h button, only hitting the start button twice (without foot on brake)
    Rick
    DogDaze likes this.
  14. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    I've tried both ways, foot-on-brake and not. Both worked, I think, but foot-not-on-brake yielded clearer confirmation of success in the display. The instructions in my manual are ambiguous on that question.
    DogDaze likes this.
  15. joedirtae09
    joedirtae09 Junior Member
    Great thread!
  16. PaulD
    PaulD Member
    53
    45
    Hillsboro, OR
    I just did this for the first time on my 2010, and did it according to the way I interpreted Bills instructions, and it didn't work.
    I would add a couple items for clarification:
    You don't have to have the brake pedal depressed.
    When you have the mph/km button depressed, press the power button TWICE.
    ETP likes this.
  17. ETP
    2,806
    1,170
    Auburdale FL
    You have to tap Dixie with your left foot and use your left hand only.
  18. compac
    52
    VA, Blue Ridge mtns
    I always have the reg odometer showing when doing the Oil mait required reset, and follow the info with door closed pwr off foot on break.
    Press and hold down and then restart the car by pushing the power on button (hold both buttons down at the same time - when the scale is fully re-set, let go of both buttons)
  19. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    can this be set/changed to come on every 10k miles rather than 5k miles??
  20. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    For some reason it can't be changed to 10k. The 5k reminder is to take it in for tire rotation and check everything else.
