HSI details
Discussion in 'Gen 3 Prius Technical Discussion' started by hobbit, Aug 1, 2009.
  1. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Strange. My Garmin shows the Prius is only 1 mph off at 35 and 65
  2. bwilson4web
    16,535
    My Garmin nuvi 260w, the stored trip log, and the mile markers by the side of the road with an iPod Touch stopwatch show our 2010 Prius indicates 1 mph high. Interesting, the trip meter average speed is dead on. But this was only for durations of +10 miles with the speed managed by the cruise control on relatively flat land.
  3. meannotgreen
    meannotgreen New Member
    33
    UK
    FWIW here is Garmin data for another run with the HSI shy of the right triangle. It does show the elevation pretty flat but that's about all really. Maybe cos I've got a basic Garmin but the waypoints at these speeds are 10 seconds and more apart and only accurate to a second. (Strange that at low speeds the waypoints are 1 second apart.)
    I saw a max much higher than that shown and the Garmin itself shows 90 was achieved.
    It is difficult to keep the HSI just shy of the right triangle. It keeps falling away and then you seem to have to apply more throttle to keep it there. The feeling is that as the speed increases you need more and more throttle to keep the HSI at that point.
    I don't feel I've got near what is possible.
    Column 1 Column 2 Column 3 Column 4
    0 Elevation(Metres) Time(Seconds) Distance(Miles) Speed(mph)
    2 12.15 12 0.1699156 50.97
    3 12.15 12 0.1741885 52.26
    4 11.67 15 0.2351334 56.43
    5 10.71 14 0.2275897 58.52
    6 9.75 14 0.2987620 76.82
    7 9.27 13 0.2909098 80.55
    8 10.23 14 0.3345445 86.02
    9 11.67 12 0.2898496 86.95
    10 13.60 9 0.1992136 79.68
    11 16.96 14 0.2945532 75.74
    12 19.84 9 0.1947679 77.90
    13 22.25 10 0.2248115 80.93
    14 24.17 9 0.2092138 83.68
    15 25.61 8 0.1786248 80.38
    16 27.53 10 0.1928785 69.43
  4. bwilson4web
    16,535
    I plotted the power changes that would reflect the change in potential and kinetic energy:
    This data pattern is consistent with a non-linear coefficient of drag. What this means is somewhere between 25 (58 mph) and 34 m/sec (78 mph,) the ZVW30 may have a local drag minimum. Certainly this is an area I'm going to be investigating in the future.
    One question about your GPS data, does it include an absolute time stamp? I took the 'seconds' as a duration at a given value. To plot the elapsed profile, I added up the individual seconds.
    There is one other possibility, traction battery recharge. I noticed that a previous Pulse and Glide segment had brought the traction battery indication down to 3-4 bars. When I started the last equivalent steady speed, there was a significant charging of the traction battery in the first part of the 14 mile run. That steady speed run had an unexpected, low mileage compared to the the first, steady speed run.
    There are other hypothesis that could explain this pattern.
    Do you remember the traction battery bar level at the beginning and end of the run?
    Thanks,
  5. meannotgreen
    33
    UK
    Yes, my Garmin is a nuvi 200W so the data format is probably similar to yours.
    Date part removed:
    Column 1 Column 2 Column 3 Column 4 Column 5
    0 Elevation(Metres) Time Elapsed (Seconds) Distance(Miles) Speed(mph)
    1 12.15 09:42:23 12 0.1699156 50.97
    2 12.15 09:42:35 12 0.1741885 52.26
    3 11.67 09:42:50 15 0.2351334 56.43
    4 10.71 09:43:04 14 0.2275897 58.52
    5 9.75 09:43:18 14 0.2987620 76.82
    6 9.27 09:43:31 13 0.2909098 80.55
    7 10.23 09:43:45 14 0.3345445 86.02
    8 11.67 09:43:57 12 0.2898496 86.95
    9 13.60 09:44:06 9 0.1992136 79.68
    10 16.96 09:44:20 14 0.2945532 75.74
    11 19.84 09:44:29 9 0.1947679 77.90
    12 22.25 09:44:39 10 0.2248115 80.93
    13 24.17 09:44:48 9 0.2092138 83.68
    14 25.61 09:44:56 8 0.1786248 80.38
    15 27.53 09:45:06 10 0.1928785 69.43
    Sorry no.
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Okay, it kind of makes sense about having to put your foot
    farther into it as your speed increases -- more *power* to push
    at the higher speed, etc, going up as that annoying cubic
    relationship. Hopefully the HSI is still a good guide as
    far as acceleration goes. Well, one of thes days I'll get an
    injection monitor onto one of these and really see what's going
    on. More watching of LOD and RPM on a scangauge might provide
    more interesting data too, as they're generic parameters
    accessible via OBD-II and it's probably going to be a while
    before anyone noodles out custom XGauges for the 2010.
    I finally spotted my first 2010 in the wild in the Boston area;
    I was on a *bus* going the other way... a friend was also off at
    a dealer's that same day test-driving one of the two they had
    around, so they're finally here but not all over the streets yet.
    _H*
  7. wfolta
    wfolta Active Member
    366
    146
    Washington DC
    2018 Prius
    I've been trying to figure out something that may fit here. There are several long, gradual uphills on my way to work and I can feel a huge difference in the engine/MPG when I am going 65-70 versus, say 55-60.
    Some of this may be that with a 55 MPH speed limit, the higher speed lets me bleed off more MPH to maintain engine RPM and MPG -- and perhaps not notice the speed drop if I'm more focused on traffic and mileage -- but I've definitely noticed times when this does not seem to be the case.
    I was speculating that perhaps the engine has a sweet spot in that range corresponding to 65 MPH interstate speed limits, but perhaps there's a drag thing happening. (Or both.)
  8. bwilson4web
    16,535
    Thank you!
    With the individual data points, I was able to construct a spreadsheet and convert to SI units for an energy analysis. I've attached the spreadsheet so hopefully you or anyone else could use it to analyze their own GPS data. BTW, some of the data points look interesting, 9:44:20-9:44:55. I'm not sure the non-linear coefficient of drag hypothesis makes sense.
    Thanks,
  9. hobbit
    4,089
    469
    Bahstahn
    Now that I've gotten through the latest maintenance page for
    now I want to try and get back to finishing up some other things,
    so this thread is getting a little bump. In the meantime I've
    quite suddenly, like just over the last 2 months, started seeing
    *many* more 2010s running around the Boston area. Good stuff.
    Now, I'd like to go back and try and get rid of all those
    leftover "XXX" comments in the HSI writeup. Thus, 2 questions:
    Have any owners gotten more used to the HSI and how the car drives
    and found any more stuff in the article that's flat-out wrong?
    It should get corrected.
    Any Beantown-area 2010 owners into the idea of getting together for
    a little experimentation/data-logging?
    _H*
  10. Tideland Prius
    16,680
    For the EV part, for sure I've gotten it up to the 2nd half of the Hybrid Area. I can't remember if I'm able to go into the PWR region but I might've have done a sliver before but never a full PWR bar.
    At 90kmh/, it's about 1/3 into the Hybrid Area (in ECO mode), so a full bar has to be much faster.
    I can't answer the 3rd XXX. However, note that if you're braking via regenerative braking and then shift into B, the CHG bar shrinks to slightly more than "letting go of the accelerator" type regeneration. Interesting.
  11. hobbit
    4,089
    469
    Bahstahn
    Thanks, this is useful.
    EV mode in a second-gen allows quite a bit more pedal demand
    above the threshold where the engine would normally light; so it
    seems like the HSI is reflecting that. At nominal SOC in my
    rig the breakover point is about 50 amps, 10 kW ... but in EV
    mode I can push more like 80, maybe 90 before it self-cancels.
    To me this is even more parallels with how the 2nd-gen system
    works and a reasonable representation thereof on the HSI.
    90 km/h, that's about 56 MPH... at a third of the way up the
    engine-run half. Hmm. Sounds rather reasonable in terms of what
    I know my sweet-spot hump to be, i.e. if I go to minimal efficient-run
    range that's probably about what speed I'd be making too. It's
    the other end, the "I got to 90 MPH and ran out of road", that's
    still a bit perplexing.
    In B the "chg" bar probably shrinks because the engine is taking
    some of the stopping load, so you need less at the regen level
    for the same stopping force. Entirely reasonable.
    _H*
  12. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    Thanks for the bump, hobbit. I find the HSI to be an alluring gauge, though I can't say I've ever really understood it that well. Before I had any idea what it really was telling me, I felt that it was the most useful of the MID displays.
    Please keep this thread updated with your comments, observations and questions.
    Oh! Almost forgot:
    I believe that in a short (but steep!) hill climb I was able to reach the Power area in the HSI while in EV mode. I know I've gone far, far to the right (on the HSI meter) in EV, while I think I've also "broken" into the EV mode while not forcing the ICE to start.
  13. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Today on the way to the airport I had full bars of battery less one and while in EV Mose had the HSI up to power with about half filled without ICE light. I've never seen it go that high without the excessive gas message. Also, I found as I backed off to turn off EV mode before I hit 25mph, if I didn't let off completely, the ICE would briefly turn on before quickly shutting down.
    Also it seems as soon as coolant temps drop below 160 then I was back at 15mph EV max speed. I was above 160 but using the heater brought it down.
    Anyway, EV mode in the power range. Interesting!
  14. rachaelseven
    rachaelseven New Member
    616
    212
    Adams, MA
    Not sure if this has been noted before, but when the battery is full or full-1bar, I can take full stealth mode up past the centerline a bit without firing the ICE. It will get up to almost the end of the leaf when the battery is full, presumably because she is trying to bring down the charge to the preferred 6 bars.
  15. Tideland Prius
    16,680
    I did two more tries in EV Drive Mode with the engine warmed up.
    1. While in motion, I accelerated til I got the "Excessive Demand" message. It got ½ way into the PWR area
    2. Accelerating from stop in EV Drive Mode, I got up to ¼ of the PWR area.
  16. hobbit
    4,089
    469
    Bahstahn
    Tideland, if you used some odd character-set for fractions in
    the above I don't see 'em; can you pls edit back to flat ascii...
    _H*
  17. Philosophe
    Philosophe 2010 Prius owner
    437
    72
    Montréal, Québec (Canada)
    OMG! :eek:
    If I may: they are fully readable under Webkit (Safari, Chrome, etc.) and also under Firefox. I've booted that old fashioned Vista to try it under the outdated IE 7 and everything is fine.
    ASCII brings us back to the '60. Unicode was adopted in the '90 (the sole internal character set of Windows since NT in '93!). ...not that I don't keep good memories typing Alt-ASCII code on DOS to get accented chars! ;) (Alt-130 = é, 138 = è, 133 = à... still works in Vista! :D )
    I didn't even thought someone could still have issues like this today!
    In remembrance of ASCII and its legacy:
    Sorry for the disruption...
    :focus:
  18. fuzzy1
    10,707
    I think he is doing it intentionally, as part of his malware protection strategy. Some phishers are using the newer fancier fonts to make some bogus URLs look like the real thing, to slip past the wary eyes of otherwise alert users.
  19. Tideland Prius
    16,680
    It's 1/2 and 1/4 respectively.
    Philosophe, yeah I still remember a good number of ascii codes. Il fait écrit en français plus facile.
  20. hobbit
    4,089
    469
    Bahstahn
    I read my forums in Lynx for a whole slew of very good reasons.
    _H*
