HSI only Turns Off Temporarily?
Discussion in 'Gen 3 Prius Technical Discussion' started by GSW, Aug 24, 2009.
  1. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    At the "Settings" menu I can turn off the HSI display, but when the car is turned off and then back on I get,"Welcome to Prius". Then the HSI screen is on again. Am I missing something or can you not just turn it off until you want to turn it back on again? Its not a big deal and I like the HSI display, but, it sure would be nice to control SOME of the items without Toyota deciding what you need to have on, like the @#*! reverse beeper.:mad:
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    There are several things that go back to their default condition when you shut the car off then restart it. Didn't know that was one of them, because I want my HSI display on all the time, but apparently it is.
    At least the reverse beeper and the seatbelt beeper stay off. I wonder if they will reset when the 12 Volt battery is disconnected? Fortunately12 Volt batteries usually last 5 to 7 years so I don't need to worry about that for a while.
  3. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    :eek: Oh Tom, don't say that about the reverse beeper. :D
    I still like the HSI display and have given up turning it off. Its nice to be able to have a quiet dash every now and then though.
  4. bokone
    bokone Junior Member
    25
    Columbus, OH
    If you are in Eco Mode, the display will always go back to the hybrid system indicator. You can scroll to settings and turn the whole thing off I believe but you cannot make it stay on a different "screen" in Eco.
  5. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Aha! I'll try it with ECO mode off. Thanks Bokone!
