Hubbell Twist lock charger cord?
Discussion in 'Prime Accessories and Modifications' started by MarcelloS, Jun 6, 2017.
  1. MarcelloS
    MarcelloS New Member
    New Jersey
    Hello. I just got a 2017 Prius Prime and love it.
    My place of work allows me to plug in for free. But the charge port is a "Hubbell Twist Lock" 125V, 20A outlet. So the charger cord that came with the car doesn't fit it. Any idea where I could get a good cable that fits this type of outlet?
    Thanks!
  2. alexcue
    alexcue Active Member
    344
    307
    So Cal
    Son of Gloin and giora like this.
  3. MarcelloS
    New Jersey
    Excellent! Thank you.
  4. alexcue
    344
    307
    So Cal
    You are very welcome! Enjoy your new car and the ability to charge at work!
  5. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    99
    Rochester, NY
    I believe what you need is a 5-15r to L5-20p adapter cord or adapter plug. "google" it or go to any good hardware store and you should find something to solve your problem.
    #5 34Hupp, Jun 6, 2017
  6. 34Hupp
    62
    99
    Rochester, NY
  7. giora
    giora Senior Member
    1,966
    721
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    My advice, use an adopter plug and do not replace the cord or cut the plug and replace it. Your EVSE has a special protection against plug/outlet excessive temp. rise, this includes a thermistor embedded into the stock plug, without it - the EVSE will not work and will give you an error message!
  8. 34Hupp
    62
    99
    Rochester, NY
    The one I posted earlier is such an adapter; The 110v Toyota EVSE will plug into the adapter, and then the other side of the adapter will "twist" lock into the 20 amp receptacle. You can also get the adapter that is built into a short cord like this.
  9. Shaun_Collins
    Shaun_Collins Junior Member
    48
    Tulsa / Broken Arrow / Catoosa Area
    That socket is also commonly called inductrial safety twist-lock type. We are required to us only those type. Our maintenance electricians and tool crib give them out.
    LG-H918 ?
Loading...
