Hubble in trouble
Discussion in 'Environmental Discussion' started by bwilson4web, Jun 17, 2021.
  1. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Compared to the first mission to correct Hubble's "eyesight", a mission to retrofit a new computer should be pretty easy. Considering a new computer that can do way more than the old one could do would be smaller, faster, and operate on less power - there'd probably be room to spare to install a few extra goodies as well.
  2. bwilson4web
    16,535
    My understanding is more than one hubble reaction wheels have failed.
    Valiant V likes this.
  3. fuzzy1
    10,707
    Why should it be any different, easier or harder? They figured out how to implement those 'eyesight corrections' with standard equipment bay swaps.
    One of the five instrument bays has been offline, in hibernation, since the last servicing mission. That is where "extra goodies" could be targeted, though that hibernating instrument can also be left as a backup to a particular active instrument.
  4. Valiant V
    Valiant V Member
    239
    161
    Winnsboro, TX
    Designing and building a device to make up for flaws in the mirror - and then installing it in space - was a task that nobody even knew would be successful. Which is why there was such elation when it actually worked. It's not like it had been done before - at least not at this scale or under these circumstances. Sure, they conceived, designed, and built something that would fit in a standard equipment bay, but it's not like it was an off-the-shelf spare part. Consider too that NASA had a considerable amount of egg on it's face because of the money and time spent building the thing and sending a defective telescope into space. They pretty much had to fix it to save their reputation and years worth of "I hope you are gonna do this better than Hubbel" jabs every time they asked for funding.
    Yanking out a computer card rack and retrofitting it with another, more modern computer, is something that has been done so many times over the past 40+ years that is should be considerably easier.
    As for the "extra space" point - look at your smart phone. Now look at one from the 80's.
  5. fuzzy1
    10,707
    It looks like the biggest ion engine project to fly so far was Dawn. It achieved a delta-v of 25,700 mph on a craft with a dry mass of 1647 lbs, over an engine run time of almost 6 years.
    Hubble to ISS needs a delta-v of 7000 mph for a payload of 24,500 lbs, i.e. 4X larger. With Dawn's engines, that will take 24 years. Neglecting air drag on the solar panels powering the engines, which really isn't negligible at that 'low' altitude.
    They'd better hurry up with designing and making larger ion engines to get it done while ISS is still operating. The latest decommission date I've seen is 2030.
  6. bwilson4web
    16,535
  7. fuzzy1
    10,707
    What was he smoking?
  8. ETC(SS)
    7,555
    So far?
    12-13 Starships.....
  9. bwilson4web
    16,535
    Every other rocket maker!
  10. ETC(SS)
    7,555
    It's not hard to beat dot.gov......
  11. fuzzy1
    10,707
    I was thinking from a science observatory perspective, not a rocket perspective. Put humans on an astronomical observatory in space, and suddenly it is going to need an image stabilizer to cancel out all those vibrations and disturbances from moving humans. Maybe even from their heartbeats.
    The waste exhausts continually being vented overboard also won't be great to the instrument functions.
  12. bwilson4web
    16,535
    Ok, where is your rocket?
  13. ETC(SS)
    7,555
  14. bwilson4web
    16,535
    Beating the dot.gov rocket?
  15. ETC(SS)
    7,555
    I forgot the rule that you have to have done a thing to effectively or accurately criticize a thing.
    I'll have to remember that the next time I criticize P45, because despite the fact that I ran and failed to get elected as the 73rd governor of the commonwealth of Virginia....I'm clearly not qualified nor do I have standing to point out that our 45th President probably wasn't our best one.
    I can't even point out (accurately, as it turns out) that UNLIKE my more successful opponent in Richmond, I have never worn blackface. ;)
  16. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    The mil spec 386 in the Hubble is much more resistant to solar radiation, emp and thermal events than modern hardware,
    Might as well keep what works reliably and add a couple modern touches rather than re-engineering the proprietary equipment
  17. fuzzy1
    10,707
  18. Mendel Leisk
    42,347
  19. bwilson4web
    16,535
    Source: ‘Hubble is back!’ Famed space telescope has new lease on life after computer swap appears to fix glitch | Science | AAAS
    The iconic but elderly Hubble Space Telescope appears to have been resurrected again after a shutdown of more than a month following a computer glitch. Science has learned that following a switch from the operating payload control computer to a backup device over the past 24 hours, Hubble’s operators have re-established communications with all the telescope’s instruments and plan to return them to normal operations today.
    “Hubble is back!” Tom Brown, head of the Hubble mission office, emailed to staff at the Space Telescope Science Institute at 5:56 a.m. “I am excited to watch Hubble get back to exploring the universe.”
    fuzzy1 and Mendel Leisk like this.
