Hubble in trouble
Discussion in 'Environmental Discussion' started by bwilson4web, Jun 17, 2021.
  1. tochatihu
    tochatihu Senior Member
    9,982
    3,851
    Kunming Yunnan China
    2001 Prius
    "In the second, third and fourth months: Initial optics checkouts, and telescope alignment. Using the Fine Guidance Sensor, we will point Webb at a single bright star and demonstrate that the observatory can acquire and lock onto targets, and we will take data mainly with NIRCam. But because the primary mirror segments have yet to be aligned to work as a single mirror, there will be up to 18 distorted images of the same single target star. We will then embark on the long process of aligning all the telescope optics, beginning with identifying which primary mirror segment goes with which image by moving each segment one at a time and ending a few months later with all the segments aligned as one and the secondary mirror aligned optimally. Cooldown will effectively end and the cryocooler will start running at its lowest temperature and MIRI can start taking good data too."
    https://www.webb.nasa.gov/content/about/orbit.html
    Non-jinxing has worked so well that I an reluctant to change course.
  2. bwilson4web
    16,535
    In a couple of years, SpaceX could probably launch a fully assembled Web sized telescope.
  3. tochatihu
    9,982
    3,851
    2001 Prius
  4. bwilson4web
    16,535
    I’m pretty sure there are three L2 but I’d have to ask Mr. Goggle. With three Web instruments, polar inferiority along the solar axis would be awesome.
    ps. This is something our anti-mask and anti-vaxx members are unlikely to understand. <SIGH> They blind themselves to so much of God’s beautiful universe.
    #104 bwilson4web, Jan 24, 2022
    Sapphire Dragon likes this.
  5. tochatihu
    9,982
    3,851
    2001 Prius
    polar inferiority eh? Glerble.
    This may well be the decade (or two) when L2 gets loaded up with with shiny gadgets. It is quite spacious though. If I read right, JWST donut will be earth-moon-distance diameter, and it will take 6 months (?) to make its loop.
  6. bwilson4web
    16,535
    Long time scale inferiority remains a technology challenge…unless I don’t understand the physics. <GRINS>
  7. fuzzy1
    10,707
    The other two observatories at L2 are GAIA (astrometry) and Spektr-RG (x-ray), which won't combine with JWST for interferometry. I don't think JWST will work for interferometry either, it seems to take purpose-built systems.
    If you mean using different L-points for interferometry, that would be just a radio-astronomy project for the foreseeable future. Their separations are vastly greater than we could consider for optical work now or anytime soon.
    tochatihu likes this.
  8. bwilson4web
    16,535
    An interferometer on an Lx scale requires an accurate 'clock' to all receivers. A satellite in a highly elliptical orbit to the observatories central axis could provide a laser 'clock' to all. Then measure the phase angle of the observatory photons of the common, remote target(s), adjusted for solar gravity and orbital Dopler effects and extremely high accuracy should exist. In theory limit, one half the wavelength of any single, common frequency being used.
    Then theory crashes headlong into experimental engineering and costs. Longer wavelengths would be less difficult and more affordable.
    #108 bwilson4web, Jan 25, 2022
  9. fuzzy1
    10,707
    I remember when the first Very Long Baseline Interferometry reached baselines comparable to Earth's diameter. I think (but don't quote me) that they were using the 21 cm hydrogen wavelength, recorded separately on videotape, with separate local clocks. Analysis was all in post-processing after the recordings were brought together at a central location, and accuracy was limited by the relative stability of the separate clocks. Since then, they have pushed this to much shorter radio wavelengths (higher frequencies). These methods work with orbiting satellites too, though the data link is no longer by videotape.
    The optical interferometry that I've read about doesn't involve separate individual clocks, or down-conversion and recording, at each receiver. Instead, the signals are physically piped together to a central location, and put into an optical combiner in real time. This limits the baseline, and is where the existing engineering crashes when applied to satellites. It seems that it will be a while until the existing radio methods can be pushed all the ways up to optical frequencies.
  10. fuzzy1
    10,707
    Temperatures of 50 and 49 Kelvin today, respectively, getting closer to the target of 40 K.
    And the first star image is in too, a Big Dipper star split into 18 pieces. And they've already identified which piece belongs to each mirror, a necessary step before starting the long series of adjustments:
    iplug and tochatihu like this.
  11. tochatihu
    9,982
    3,851
    2001 Prius
    Let another post the 'selfie' as it is surprisingly 'fuzzy' :)
    For mosaic posted above I'd feel better if each segment's aberration pointed at the center 'of mass'. Only those in Mission Control know if this portends anything at all.
    Segment A4 is really out there. Tilt better, you hunk of beryllium.
  12. fuzzy1
    10,707
    From the team's posting, it seemed that they were pleased the image pieces were as close as they are. The test field covered a much larger area, in case some were much farther out.
    As for the shape and direction of the image pieces, that would definitely be a concern if the mirror segment adjustments had only 3 mounting points, or degrees of freedom. But with 6 adjustable mounting points each, plus a separate curvature adjustment, it seems too early to be concerned. I also wonder if they deliberately applied different small aberration shapes and orientations to different mirrors as part of the identification process.
  13. tochatihu
    9,982
    3,851
    2001 Prius
    Darn clever thoughts from a fella now suffering COVID aberrations.
    fuzzy1 and Merkey like this.
  14. fuzzy1
    10,707
    It is too early to spot any potential long-covid symptoms. Though a very short drive to an appointment this morning revealed that I ought not be driving that soon after waking up.
    bwilson4web likes this.
  15. tochatihu
    9,982
    3,851
    2001 Prius
    Try some wordles? Don't drive at night?
  16. fuzzy1
    10,707
    Isn't Wordle addictive? Just what I need, more electronic addictions. ;)
    I've already cut back night driving due to cataract development, and am not expecting to be ready for surgery for a few more years.
  17. fuzzy1
    10,707
    Now the image pieces have been moved into a close array matching their mirror positions:
    It is encouraging to be seeing interference fringes now, a sign that the process is progressing.
    The next step will be focusing each individual image. Later, they will be stacked together, followed by fine phasing adjustment.
  18. fuzzy1
    10,707
    Two more steps of major progress posted today!
    First is a successful Segment Alignment, in which all the mirrors are individually focused,. Notice the 18 mostly beautiful Airy disks, nice tight circles surrounded by a diffraction ring or two:
    Then they were all stacked into a single image:
    The many interference bars in the hex spikes show that the mirrors are still out of phase, they have different heights. The next step is Coarse Phasing, which will bring the mirrors much closer to matched heights. That is followed by Fine Phasing, which ought to make this stacked image more like a bright version of one of the images in the first frame, a nice tight circle with one or two visible diffraction rings.
    iplug likes this.
  19. bwilson4web
    16,535
    Why the six pointed star around the core?
  20. fuzzy1
    10,707
    I think that is a diffraction artifact caused by the hexagonal mirror configuration. It should shrink sharply with the Coarse and Fine Phasing, but may never go completely away. Even if it does vanish, there will still be a 3-pointed star caused by diffraction around the Secondary Mirror supports.
