HUD and Polarized Sunglasses
Discussion in 'Prime Audio, Electronics, and Infotainment' started by mr88cet, Jan 18, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    One thing that polarized sunglasses do is reduce light reflected off the top of the dashboard onto the inside of the windshield. So, does the HUD work with polarized sunglasses?
    52,891
    i wish i had tried that on my test drive, but never thought of it.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Depends on the glasses. When I had my eyes dilated for a test I put my sunglasses on I could still see the HUD. I was a bit dimmer but still visible.
  4. mr88cet
    2,313
    1,335
    Austin, TX
    Were those sunglasses polarized?
  5. priuscatprimeguy
    2,730
    2,640
    yes
  6. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    Short answer is no. Long answer is during the daytime, you'll see nothing. During the nighttime (why the hell should I wear sunglasses at night? Hell, just for testing purposes), the HUD is visible to some extent.
    KrPtNk and priuscatprimeguy like this.
  7. Db17
    Db17 Member
    188
    92
    Visalia, CA
    In my car the HUD is 95% wiped out when I'm wearing sunglasses. It can also be wiped out if you pull up to a car in front of you at a stop and your headlights reflect back into it. Likewise reflections from a car driving in front of you can do it too.
    The easy test is to turn your sunglasses 90° and see it come and go.
    priuscatprimeguy likes this.
  8. mr88cet
    2,313
    1,335
    Austin, TX
    Thanks for the reply.
    Does it matter whether they are polarized sunglasses vs. unpolarized?
  9. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Polarized glasses will kill it. Non polarized glasses will just darken it according to how dark the glasses are. Again, if you turn polarized glasses sideways then you will be able to see the HUD.
  10. Tideland Prius
    16,683
    So you basically have to drive with your head tilted to one side? o_O
  11. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    I take it's some LCD projector or some other technology, instead of the VFD in the 3rd gen Prius? That's disappointing because the latter works fine for me with polarizing sunglasses - I may need to turn it up to max brightness but I can never not see it.
  12. alexgrigori
    alexgrigori Active Member
    163
    109
    Technology
    RTFM, according to manual - non compatible. Practically - barely visible.
  13. mr88cet
    2,313
    1,335
    Austin, TX
    So much for the HUD it would appear... Well, it will work, and help sometimes. Thanks for the info!
  14. Db17
    Db17 Member
    188
    92
    Visalia, CA
    Yep, it's a reflection and that what polarized glasses do ... they remove reflections.
  15. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I can vouch for this, barely visible with polarized lenses for me (MFD screen, no HUD).
    ruby likes this.
  16. mr88cet
    2,313
    1,335
    Austin, TX
    Actually, I spoke a little too generally there. Still potentially usable at night, or fairly-early mornings and fairly late evenings, or on cloudy days, I'd bet.
    Actually, I've only comparatively recently again started using sunglasses, so, it's probably usable. I'm sure other P.Prime Advanced drivers will find uses for the HUD.
