HUD not working after disconnecting battery
Discussion in 'Prime Main Forum (2017-2022)' started by randerson9248, Oct 22, 2020.
  1. randerson9248
    randerson9248 Junior Member
    66
    SF Peninsula, CA
    2017 Prius Prime.
    Battery went dead again. Was going to get a new battery, but when I disconnected the negative battery terminal, I saw the connection was corroded. Cleaned up the terminals and the battery charged up fine.
    But now have several things not working: Radio doesn't recognize sirius subscription; will be a pain to get that resolved, but will be just time involved. All the display settings were lost; got the settings back. Check engine light is on, but that will probably go away after a few drive cycles.
    My main concern now is that the HUD no longer works. I turned it off and back on. Still nothing. I went into display settings and couldn't find any thing wrong there. Any ideas on how to get the HUD working again.
  2. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    The HUD has a physical button low and to the left of the steering column. Is that the problem?
    As far as XM is concerned maybe park the car outdoors a while.
  3. Tips
    Tips Member
    128
    66
    Grand Forks, B.C. Canada
    2020 Prius Prime
    Is it possible you will have to turn everything on in the set up menu! I would not think so but it looks that way
  4. randerson9248
    66
    SF Peninsula, CA
    After cleaning he terminals and charging the battery, that button was on (green led on). I turned it off and then back on anyway. Car is always parked outside. Garage is for projects.
  5. randerson9248
    66
    SF Peninsula, CA
    I checked the set-up menu and everything seemed as it should be.
  6. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    If you have not yet done so set up an account at http://www.SiriusXM.com . You can send a reset ping from there last time I checked.
    moto g(7) power ?
  7. Diemaster
    Diemaster Active Member
    302
    265
    so. cal
    Or if you have the XM app and are signed in to your account you can send that ping yourself. (used to be able to. I dont know now I dropped XM b/c the prime only gets ~100 out of 300+ stations witch is bullsh!t.)
  8. randerson9248
    66
    SF Peninsula, CA
    Sirius XM is now working. But HUD is still not working.
    I may disconnect the 12v battery again and re-connect to see if it comes back. Seems like a long shot, but don't know what else to do.
