Hud Speedometer Meter went out
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blizzwhiteprius, Nov 28, 2012.
  1. Blizzwhiteprius
    Blizzwhiteprius Junior Member
    38
    37
    Seattle, Washington
    Went to start my car tonight after I got off work and MID display was completely dark, turned off the car and started it again, the MID came back turned on headlights went off again.
    So now every time I turn on head lights the MId goes dark as do my lights for the heater and radio controls. Any one experienced this? I attached pics with lights on and with them off. Going to schedule a appointment with the dealer today. IMG_0203.JPG IMG_0202.JPG
  2. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  3. Blizzwhiteprius
    38
    37
    Seattle, Washington
    Yes that is correct thank you for the correction :)
  4. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    You may be able to edit your post's title. Have you tried turning the dimmer adjustment knob/wheel?
  5. Blizzwhiteprius
    38
    37
    Seattle, Washington
    When I went to go check the car this morning turned on the lights everything worked fine, it is at the dealer at the moment so will see what they come up with.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Dimmer rolled down all the way.
  7. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Yup. Happened to me a couple of times. I have it set on the lowest setting at the cusp of being all the way off. I don't recall brushing my knee there but I felt like an idiot. I almost took the car to the dealer.
  8. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
  9. Blizzwhiteprius
    38
    37
    Seattle, Washington
    thats what the dealer said but i did not roll it down is the weird thing
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    You could have bumped it with your knee, or rolled it down accidentally when cleaning. It is not hard to do.
    SAMSUNG-SGH-I747 ? 2
