HUD-style instrument cluster tips
Discussion in 'Gen 5 Prius Main Forum' started by Preebee, Jun 18, 2023.
  1. Preebee
    Preebee Senior Member
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
    We've all heard the complaints about the steering wheel partially blocking the MID (multi-information display).
    Well I'm here to tell you that the current configuration works exactly as it should. It takes a little getting used to, and first impressions are giving people pause, but have a look at the following pictures:
  2. Preebee
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
    The steering wheel is supposed to "block" the bottom part of the HUD. The instruments are designed to reside just above the highest point, where your eyes naturally follow the road. Look at the photo with the wheel lower. You have all that blank space showing. That's not correct. Spend a little time with the wheel in the proper location and you'll get used to it fairly quickly. And once you do, you'll see the genius in the designer's work.
  3. Preebee
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
    I finally got the pics to upload right.
    The first picture depicts the wheel in a lowered (relative) position exposing the entire LCD screen. This is not correct.
    In the 2nd and 3rd pictures, you see the wheel much more upright and "blocking" the useless part of the instrument panel. This gives the driver a good view of important details with the eyes not wandering far from the road. Smart/safe idea, and I love it!
    I believe that setting the wheel in this position should allow for a bunch of different sized humans to see the entire screen as it was intended. But make no mistake, it WILL seem kind of weird at first. Much of this car will be an adjustment to those who have driven prior generations (even the last).
  4. Preebee
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
  5. Jim Call
    Jim Call Active Member
    107
    115
    Asheville
    2023 Prius
    I disagree that the steering was designed to cover part of the info display. Can you still see all the info if it does? Sure, but at 5'10", I and my wife who is 5'6" can both find comfy positions to see the info display completely with no blocking. Combination of seat height and steering wheel/column adjustment makes it possible for just about any size to see the entire info display with no blockage.
    theRob likes this.
  6. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Just seeing this now. I’ll test it out during my test drive tomorrow. Yep…I’m taking the Toyo tires for a test drive. : }
    Preebee likes this.
  7. Preebee
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
    There's nothing to see in the bottom third of the display. And the info that isn't blocked fits right around the curvature of the wheel. If that isn't "on purpose", then can we agree it's a happy accident. :LOL:
    Sharol and tovli like this.
  8. Preebee
    891
    781
    Midwest
    2026 Prius Plug-in
    SE
    Lock it down! :cool:
