Huge Suspension Damage from High Tire Pressure?
Discussion in 'Gen 3 Prius Main Forum' started by Sal43, Nov 21, 2019.
  1. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    It had nothing to do with following too close. It had to do with the guardrail on my right, an 18 wheeler to my left and the tailgater behind me.
  2. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    If you go by the door sticker and never rotate your tires then you'll get excessive edge wear on the front tires with almost full center tread and even wear on the rear tires those factory tire pressures are definitely not made for even tire wear,.
    You can also see that the front tires are squished a lot more compared to the rears if you only have 2 psi more in the front than rear.
    Perhaps factory psi are that low in the front for passenger comfort or protecting suspension components, because it's definitely not for even tire wear.
    RMB, Lightning Racer and bisco like this.
    52,841
    yeah, i don't see how a 4 month old sway bar link could fall off from high tire pressure
    William Redoubt likes this.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    OK fine. In that one instance maybe you were pure as fresh snow.
    But a major contributing factor in hitting an obstacle laying in the road often is not having enough reaction time after the vehicle ahead runs over it.
    I hope the tailgater got suspension damage too.
  5. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Maybe the high tire pressure caused the sway bar link to snap in half from hitting a big pothole.
    Either that, or the mechanic forgot that the suspension has to be under load before fully tightening the sway bar link.
    If you tighten the sway bar links while the car's on the lift, then they will be loose once you put the car back on the ground.
    #25 Sal43, Nov 23, 2019
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Not sure if not rotating tires is recommended.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I'll rule that uneven level of the vehicle height and weight distribution due to unorthodox psi of the tires caused or shifted stress to the set of suspension and became defective sooner than later.
  8. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    There are millions(probably even trillions) of unavoidable potholes here are in Pennsylvania especially with low beam headlight technology from the last century like my 2004 Impala has(that generation started to be manufactured in 1999). You have to choose the lesser of 2 evils between avoiding a pothole and then hitting another vehicle or hitting a pothole and avoiding getting in an accident with the tailgater behind you, oncoming traffic, or the car in the lane traveling the same direction as you.
  9. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    The sway bar connects the left and right control arms and wheel hubs together NOT front to back.
    The front left and right tires had the exact same tire pressure so what you said makes no sense.
    Also, if anything, increased tire pressure in the front would increase the weight distribution toward the rear of the the car not the front.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    I politely disagree. The sway bar links that I put on my 2010 had a definite machined step that engages on both the sway bar and the strut. If the step is in its proper place, then weight on or off the suspension is irrelevant.
    Grit likes this.
  11. Mendel Leisk
    42,342
    Wait what??
  12. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Did you read the posts? These were about the sway bar links picture in the photos in the first post. It's for a 2004 Impala and a different design than a gen 3 Prius. It absolutely does need the suspension to be loaded when tightening the sway bar links.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    After reading the entire thread, I’m still going to politely disagree. If you tighten the sway links down until the bushings no longer rotate under the washers, weight on or off the suspension makes no difference.
    Grit likes this.
  14. sam spade 2
    7,035
    2,804
    2017 Prius c
    It is not YOUR responsibility to avoid taligaters behind you.
    They get brake lights from me.
    (Not wanting to turn this into an argument.......but just had to make that comment.)
  15. sam spade 2
    7,035
    2,804
    2017 Prius c
    Well now we have veered off on a tangent......yet again.
    But in some locations (countries, continents) I've been told that virtually NOBODY ever rotates their tires.
  16. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    The original post began in a tangent o_O
  17. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Very modest of you, they get the brake slams from me...from the top ropes. One-two-three.
  18. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Prius and Prius v use different front and rear shocks.......
    #38 Tim Jones, Nov 24, 2019
  19. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    WRONG, you will never be able to fully tighten the sway bar link on an Impala if vehicle's weight is not being supported by the suspension. Here's a video proving this. This is a Chevy Monte Carlo which is basically an Impala Coupe.
    It has many interchangeable parts including the entire driver train and most if not all suspension components.
    This guy has a hydraulic lift, why does even need a jack stand if the suspension did not need to be loaded?
    Go to about 2:36 in this video.
  20. William Redoubt
    William Redoubt Senior Member
    1,228
    1,174
    Coronado Island, California
    Agree. Recommended pressures are estimates for average conditions within a safety zone that reduces risk and liability to the tire and auto manufacturer. Think about it. How can Toyota, maker of the car, specify a tire pressure when they don't make the tire? The only tire they can provide a recommendation for is the one they test with. And keep in mind that temperature, barometric pressure and the length of the driving cycle affect every tire every day.
