Human/Prius Centipede
Discussion in 'Gen 3 Prius Main Forum' started by Tommy West, Oct 22, 2023.
Tags:
  1. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    410
    2013 Prius Plug-in
    the thing is... the size "1500ah" I don't think you realize the size of that battery will be!
    I have two 12v 85ah batteries and each is connected to a 2000w inverter. This is all you need... plus, between all the addon electronics, servers, and other networking equipment I have... I highly doubt you'd pull more power from the batteries/inverter as I do and my next upgrade is to lithium 12v batteries made by using my PIP HV battery cells.
    https://black.jmyntrn.com/2023/07/13/between-my-two-power-inverters-i-am-looking-for-a-smaller-option/
  2. Tommy West
    Tommy West Junior Member
    51
    In a Prius
    They will be rigidly joined together thru some kind sort of quick connect hitch mechanism that I find on the internet and buy or build and weld into both cars so I can connect or detach at will and use one car to make my 200-$400 a day I make doing courier work. I only need to attach when I need to move both cars at once since it will be tedious to have to move one car and then walk back and get the other car and drive it ahead and then walk back and get the other car and drive it ahead and walk back and get the other car all the way from Michigan to Arizona. Once i get the two cars gas and brakes synchronized properly I'll build a small foamie camper with the same connections that can be attached in-between the two cars and once I have that all worked out I may build a shell to enclose the whole shabang to make it look like one unit from the outside
  3. Tommy West
    51
    In a Prius
    I have four 310 ah lifepo4 cells in the floor board of the Prius now. Those will be the majority of my power. I still need the bms and I'll going to use Walmart cutting boards to compress them and build the box. I still need the bms and everything. Any prebuilt store bought stuff is for suckers. We'll keep building our own stuff huh?
  4. Tommy West
    51
    In a Prius
    I have four 310 ah lifepo4 cells in the floor board of the Prius now. Those will be the majority of my power. I still need the bms and I'll going to use Walmart cutting boards to compress them and build the box. I still need the bms and everything. Any pre built store bought stuff is for suckers. We'll keep building our own stuff huh? Plus it's more fun too
  5. Tommy West
    51
    In a Prius
    So using this picture as an example. If the car in front was a Prius and in the back part of this rear shell was another Prius and the middle part was a small RV and the front Prius can be detached and driven off and or the rear Prius can be detached and backed out of the shell and driven off. Both priuses will accelerate when you press the gas on the front Prius and both will brake when you press the brake when they are connected. Pretty simple.
  6. ChapmanF
    18,970
    The go pedal is entirely by-wire.
    The brake system, though, is not.
  7. Tommy West
    51
    In a Prius
    So I need an actuator on the brake pedal of the rear car that mimics the movement of the brake pedal of the front car. I found a great maker space to do anything I need to but winter will be chasing me out of Michigan soon unfortunately so I'll be doing the work in Az or CA. https://www.lakeshorefablab.com/
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    How do you go about getting legitimate registration and insurance for this?
  9. Tommy West
    51
    In a Prius
    Separate vehicle will be registered when I buy it. I'll have my cars tow each other how ever I want by golly I'm not manufacturing any new vehicles just one pulling another. If I tied a string to the rear car's throttle and just pulled on it with my hand to make the rare car help pull the load would I then also have to re-register the two vehicles as one? I'm just towing things in an what seems to be odd way....since most of the other Monkeys on this planet are not as evolved as me and the things I do scare them . It's always been that way. I'm used to it by now just like the wind ️ unless it kicks up real fierce I don't even notice it. As always I do need technical assistance on this because if not the W.A.M. will be always overheating #diginomad on youtube
  10. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Can I get 3 Prius'? 3,3,3,3,3! Can I get 3?
    How about 4? Can I get 4??? 4,4,4,4,4???
    5! Can I get 5 Prius' in a row?
    Come on now, don't wimp out with just 2!!! Let's get 6!!!
  11. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Those who believe this about themselves are usually misinformed....
    and yet you can't figure out why one car would not act exactly like another if they both had a single identical signal?
  12. Tommy West
    51
    In a Prius
    There are a million possible very successful ways to do what I wish to do including very many oh so very clever implementations of string and rubber bands.... Any one of which would be oh so very interesting to design and build. I would probably choose one of the alternative methods to string.
    I do believe there is an electric motor that controls the throttle ultimately. So it must receive a signal telling it when and how much to do of things throttley hence I boldly propose that if a similar yea even a signal of identical religious convictions was carried thru a series of tubes to the second electric motor that it would commence to doing the exact same, how and much of all throttley things.
  13. Tommy West
    51
    In a Prius
  14. ChapmanF
    18,970
    Wouldn't it be simpler to just learn how the car works, and then know what you were doing?
    There is an electric motor at each throttle. And a spring. The motor can open it. The spring can close it. The signals going to the motor are pulse-width modulated: the wider the pulses, the more the motor will push against the spring.
    How does a system like that achieve a target throttle position? By also having a sensor that reports the throttle position. That goes back to the computer that makes the pulses, so the computer can see how it is doing, and adjust the pulses to get the position where it wants, even though the motors are never quite the same and the springs are never quite the same and the flowing air also pushes on the throttle.
    What would you propose to be doing through your series of tubes? Duplicate the pulse train being sent to one throttle motor that's under feedback control based on what its position is, and just send the same pulses to a different motor in a different car with a different spring and with no feedback of where its position is, and hope for the best? It's like thinking you can dribble two basketballs by doing identical things with both arms, while only able to see and feel one of them.
    Or how about this: since each car already has its own motor and its own spring and its own feedback circuit and its own computer that gets the feedback and knows how to control its motor, why not use your series of tubes to tell those computers how much go you want, and let them do the job they already know how to do?
    But would you be sending how much go you want just to the engine control computer in each car? In a Prius, take a step back. Each car also has another computer, called the power management control ECU, that not only knows the car has an engine, it also knows the car has a battery. And when you tell that computer how much go you want, it knows how much go it can get from the battery, and how much go it can get from the engine, and it coordinates the two, and decides how much go to ask the engine computer for, and then the engine computer does the job it already knows how to do with the throttle. And if the two cars haven't got batteries in identical condition at identical state of charge, the computer in each car will know how to do the coordination right for that car, even when that might mean asking for a different amount of go from the engine control computer.
    So, how do you go about telling the power management control ECU how much go you want? Well, it turns out there's a pedal for that, wired right to it, with six wires.
    Why not just use that to tell the cars how much go you want, and let the computers that are already there do the jobs they already know how to do?
    #34 ChapmanF, Oct 29, 2023
  15. Tommy West
    51
    In a Prius
  16. Tommy West
    51
    In a Prius
    So I just need an actuator on the break pedal and one in the gas pedal of the rear car that mimic the movements of the gas and brake pedals of the lead car?
  17. ChapmanF
    18,970
    An actuator on the brake pedal could be needed because the brake system isn't strictly by wire.
    The go pedal is purely an electrical input, six wires to the power management control ECU. Just bringing the same six wires to the other car's power management control ECU might be worth a try.
  18. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
    how are you all missing what can be done through CANBUS? well, all but the whole steering wheel linking, once my brain started to think through that, I threw in the towel, have my own projects to think through and that one is just.. nah..
    PCAN-Router: PEAK-System
    TBH... I bet you post this to the DIYEV or Electric Car Forums, they can tell ya if it's possible or not. Most of those folks are not from the US and from what I've seen and learned a wealth of knowledge from, there isn't a screen name on this forum that can tell you what you need to know! They already hacked into the Gen 3 and Gen 2 Inverter and CVT...heh, powering the Prius guts from a workbench using a homemade HV battery type of folks.
  19. black_jmyntrn
    1,729
    410
    2013 Prius Plug-in
