Humming noise after charge complete
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Jun 2, 2014.
  1. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    Happened to go down to garage to get something from pip about 3 hours after charge was complete and noticed loud hum coming from right rear wheel well area.
    We had not had any lightning storms, electrical interruptions or anything odd; house is on whole house surge protection, and 240v evse has been working fine.
    Hum disappeared when car was booted up in ev for a moment and then turned off. Hasn't come back on in an hour.
    Anyone experience anything similar?
    52,861
    yes, mine too. something about the car checking things out, i forget exactly, but completely normal. freaked me out the first time i heard it.:eek:
  3. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Yes, same here. It's weird and others have reported it. It's not related to temperature as far as I can tell on my end, but sounds like maybe the battery fan goes on once in a blue moon for other unclear reasons. Not sure what the system is doing.
  4. LA2014Prius
    LA2014Prius Junior Member
    103
    2014 Prius Plug-in
    I put a bottle of tire fix in the storage area below trunk area a couple of days ago while the car was charging, I can hear fans going... This car like u guys said, constantly checking itself. When you walk by the car close enough with the key in your pocket, lights turn on inside the car... ;)
  5. crewdog
    493
    388
    Woodstock, GA
    It's not the battery cooling fan; it sounds more like an electric shaver or neon light ballast humming.
  6. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Evaporative system leak check.
    markabele, iplug and retired4999 like this.
  7. crewdog
    493
    388
    Woodstock, GA
    Would the evaporative system leak check last for 5 minutes?
  8. bisco
    52,861
  9. Astolat
    Astolat Member
    229
    73
    Guildford UK
    I've got used to sounds like that, but recently I've heard faint echoes of 'daisy, daisy, give me your answer do' coming from the speakers even when the sound system is off. Is this normal...? :rolleyes:
  10. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Well the car really only hums because it does not know the words.
    markabele likes this.
  11. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Burma Shave? :)
    Just don't ask your Prius to open the pod bay doors.
