Humming sound
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lenjack, Jun 28, 2016.
  1. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    2010, purchased new, 89k. Never a hint of a problem. Last few days, I've notice a low level humming sound at idle. Probably there at speed and swamped by road noise. No change in performance. Temps in the 85 t0 90 range, with AC always at Auto, and at 72. Any ideas? Thanks for listening.
    52,862
    inverter whine?
  3. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Compressor?
  4. lenjack
    804
    114
    Pennsylvania USA
    Would that be red or white? Sorry. I couldn't resist. If so, what needs be done, or needs to be checked. I see my dealer in a couple of weeks for inspection. This is one of the honest, reliable, and trustworthy dealers.
  5. JC91006
    16,936
    8,647
    It's probably just a hum coming from your AC. Next time you hear this hum inside your car, stop and step outside to the front of your car. If it's louder and coming from the engine.............it's your AC
  6. bisco
    52,862
    nothing to be done, these noises develop as the cars age.
  7. CR94
    CR94 Senior Member
    2,831
    1,243
    Northwestern S.C.
    Nothing, if what you're hearing is normal compressor sound. Does the humming sound stop if you turn off the air conditioning? Does the air conditioning function properly? If yes to both those questions, don't worry about it.
  8. lenjack
    804
    114
    Pennsylvania USA
    Compressor? Hadn't thought of that. Next I hear it, I'll report back. Thing is, I don't remember hearing it previously. I'll shut down the AC and check.
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,244
    Orange County, CA
    Please put in "compressor noise" in the search bar in here. You'll find out lots regarding the noise you are hearing. I'm pretty sure its your AC compressor. Read about it. Its different from any other compressor on cars. Its better.
