Hurricane Sandy - I love my Prius!
Discussion in 'Gen 2 Prius Main Forum' started by FirstFlight, Nov 2, 2012.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Sure hundreds avail but that's a massive load on the Prius. Close to 200 amps. Prius could not support that big a unit.
  2. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    That's not quite true. While the low voltage system couldn't handle a 2000 watt load, which would be 145 amps, the traction battery could easily do 2000 watts. The current drain from the high voltage battery would be approximately 10 amps. That load is not an issue for the traction battery.
    The 1000 watt inverter ran my fridge with no issues. My fridge only draws about 200 watts nominal and the peak is somewhere around 1500 watts. As mentioned in a previous post, most, if not all, inverters have overtemp/overcurrent protection. I had that exact problem (fan failure) and my inverter shut down. If you're speaking about the Prius, it has the same protections. I had zero concerns about damaging the Prius with this set-up. Getting a 2000 watt inverter, especially if you don't know what you're doing, may damage the Prius because it will exceed the current draw on the DC/DC converter.
  3. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Of course it would be great to tap into the 200v on the traction but I thought the discussion was the 12 volt.
  4. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    My installation is similar to FirstFlight. However, i bolted my unit to the floor and cut a hole for it in the plastic liner. I connected it to the battery with #6 wire. I have a 27 cuft side by side fridge, as I said before, the inrush current is too high for my 1200watt inverter, but the fridge will start when the inverter automatically restarts. I left my car in my garage and put a pipe on the exhaust to vent it out under the garage door which was open only 1'. I didn't want any trees falling on my car. I plan on ordering the 2000 watt unit, but not loading it more than 1000 watts accept for surges.
    A flooded battery is a regular car battery, not the AGM type unit in the Prius. The flooded batteries are designed to delivery large slugs of current which is normally neeeded to run the starter motor, which of course the Prius does not have.
    On another note, you cannot parallel inveters to get more power. The AC outputs will not be in phase. You can use two of them, powering seperate loads, but that will not help the inrush current issue.
  5. vertex
    673
    144
    new york
    2018 Prius Prime
    I don't think we can find an inexpensive inverter to connect directly to the traction battery. That would be more efficient too. The efficiency of the series connected inverters, 240 to 12 and 12 to 120VAC is probably about 75%.
    Oh, I used about 2.5 gallons a day, with the car running for 3 days straight.
  6. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    That's not true with all inverters. There are a number of companies that make load sharing inverters where the outputs are tied together and in phase.
  7. edthefox5
    10,096
    4,840
    Clearwater, Florida
    FirstFlight your quoting me on that post. I did not post that. vertex did.
  8. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Strange. I just hit reply. I'll fix it for you.
  9. vertex
    673
    144
    new york
    2018 Prius Prime
    Yes, but not these inexpensive ones. Have you used any load sharing ones?
  10. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    what is the benefit of the more advanced set up you are doing to the traction batt?
  11. Patrick Wong
    18,213
    6,530
    A direct connection to the traction battery allows the use of a more powerful inverter and a more efficient setup since less power is lost due to heating of the connections between the battery and the inverter. For a given power output, a higher voltage allows a lower current flow. Resistance losses increase according to the square of the current flow.
  12. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    No, never used them. In your first post you said that inverters cannot be tied together to increase the power output. Now you say they can but not the inexpensive ones, which also isn't correct. Inverters cheaper than my $95 model can be configured in parallel.
    The biggest benefit is that you can use an inverter that is larger than 1kW. There will be less stress on the 12V system as well.
    One thing I'm still testing is not leaving the car in ready mode, which means ~300 watts aren't being wasted with the car just sitting there. I have to write software that will constantly check the voltage of the traction battery and when it gets to 41%, the Prius will be powered on and started. I don't know how much fuel will be saved that way or if there is really a huge benefit to it but it's something I wanted to test out.
  13. Flying White Dutchman
    4,376
    314
    So you have the keyless system where you start the car and jeep the key in your pocket?
    That would make it a little more safe.
    You can also lock the doors using the key in the fob to open then again.
    That way with a prius with out keyless you can keep the car running and fob in the slot but still have the doors closed.
    -Tapatalk
  14. Flying White Dutchman
    4,376
    314
    you guys need to make sandy power outages prius backup videos on youtube!!
  15. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    There are mil/med/ind inverters that can be had for the voltage of the traction/ev battery. Price? Discussed briefly in a thread maybe a month ago.
    My choice given time would be something like these.
    GFX1312 http://www.outbackpower.com/pdf/specs/GFX_Intl_Series_SpecSheetA4_02.2012_lr.pdf
    FX2012MT http://www.outbackpower.com/pdf/specs/98000240100_RevD_M-Series_SpecSheet.pdf
    add a fw-x240 auto transformer for 240loads with proper phase between mains legs 1 and 2. http://www.outbackpower.com/pdf/manuals/PSX-240_Installation_Manual.pdf
    Useful for backfeeding your panel to get your solar pv microinverters running as they need a grid 60hz signal to turn on and run. After disconnecting from grid to protect utility workers if your system doesn't do this automaticly.
    One large deep cycle sealed battery always charged and on standby might be a good investment.
    Still have 1000's without power here in WV also.
  16. edthefox5
    10,096
    4,840
    Clearwater, Florida
    I would imagine if your using the HV batt its because your sinking a big inverter load which would suck down the battery level fairly quickly requiring the engine/mg to start so maybe your 41% software is moot. The engines going to start quick when it sees a big load. Which is not a problem with the engine running all the time. It would not use alot of gas. The 2 problems with a big load on HV is battery heat and battery ecu becoming confused on out of range current consumption. It may throw a cel but thats no big deal but battery heat sure is. Stock fan may not work well enough.
    But its the way to go.
    Someone should manufacture a pigtail that goes in between the battery BOI (big orange interlock) and provides a drop for inverter use while mainlining oem wiring.
  17. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I respectfully don't agree with your comments regarding the CEL, battery ECU confusion and heat but I really don't have any data to discredit it either. I should have this up and running in a month or less and will make a new post with data and pictures.
  18. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    Making a pigtail that attaches to the safety interlock would do nothing for you. This doesn't connect to the positive and negative side of the battery, it just splits the battery in half. The best place to connect to the battery is where the orange wires go into the battery right near the relays.
  19. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Oops your right that just disables the relays. I was trying to think of an easy way to grab battery B+ without taking the whole battery out.
  20. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    You don't have to take the battery out. You could gain access to the terminals in 20 minutes.
