HV battery cell replace advice!!
Discussion in 'Generation 1 Prius Discussion' started by John bartz, Feb 20, 2022.
  1. John bartz
    John bartz Junior Member
    2003 Prius
    I'm brand new to hybrids and Prius and I got a gen 1 Prius that had been sitting for about a month and a half. Had a bad 02 sensor when I checked the code and needed a new 12v battery, but ran with a jump, drove good. so I grabbed it for $800. 300 miles later I got code 3006 (of course.) I've done a lot of research and watched YouTube videos. I got Dr Prius, and it looks like #6 is the bad cells. I also load tested, had the engine charge battery and put in neutral and turned on max AC (which works) headlights on bright, radio, and car stereo. Let it drain the battery then put back in park to charge. I have a video of it. At no point did it only run on the HV battery. If someone could take a look at the video I'd so appreciate it maybe you see something that a novice is totally missing, especially with the recharge.
  2. John bartz
    2003 Prius
    Video didn't upload trying to reformat. Here's some picture of biggest changes I saw first image is what it sat at before load testing, second is with headlights on and max AC blasting in neutral. Last 3 are back in park recharging (those 3 pics are about 15-20 seconds apart) and the last is what it sat at after recharging for awhile
    #2 John bartz, Feb 20, 2022
  3. drbojo
    drbojo Junior Member
    Frankfurt
    2002 Prius
    I
    I am a Resident of Frankfurt, Germany. I down a Prius 2002, 600 tkm, mica-green.
    Two modules of the HV-bty are faulty.
    I bought 10 modules from four ebay sellers located in the USA. However, ebay does not ship these modules to Germany. So I am still stuck with a car that does not run.
    Replacement modules are not for sale in Germany.
    Any suggestions? Thank u.
  4. dolj
    dolj Senior Member
    7,634
    3,850
    Wellington, New Zealand
    A fellow compatriot recently tackled this job on his Gen 2. You might get some help and/or inspiration by reading up on his adventures in this thread:
    Hybrid battery pack materials in Germany
    I hope that helps.
