HV battery clarification on terminology.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Raphael Muscarelle, Jul 7, 2019.
  1. Raphael Muscarelle
    Raphael Muscarelle Active Member
    661
    222
    Cape Canaveral Floridia
    Since the pack as a whole acts like the lowest capacity cell it's more like keeping the weakest cell as strong as it can be.
  2. Raphael Muscarelle
    661
    222
    It actually only seems like it is at everywhere at all times electricity has a speed it happens to be the speed of light
  3. Raphael Muscarelle
    661
    222
    I am also talking about what electrons are doing which is the more important factor in a battery then the watts applied to the battery.
    52,777
    electricity is beyond me
    Raytheeagle likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    me too, apparently. 33 years of working in it and I just don't get it......
    bisco and Raytheeagle like this.
  6. Raphael Muscarelle
    661
    222
    What I think is going on with charge and discharge is 2 fold and probably the word balance might be a sufficient word for it.
    1 the reversible damage lowering capacity is due to crystals building up. The complete charge and discharge sends electrons through both ways across the plates disrupting the crystals.
    2 charging from complete discharge stores more electrons at a higher voltage giving more useable electrons. This is where balancing would make sense. Having the cells more balanced set of electrons stored at higher voltage.
  7. ChapmanF
    18,958
    Another way to visualize it is pushing on a stick. You push this end, that end moves. The whole stick moves pretty much at once.
    "Pretty much at once" ≠ "exactly at once", or even quite at the speed of light, in most cases. There is a velocity of propagation. Give a nudge to one electron at one end of a wire, and the next one will move, because the first one got a smidge closer and repelled it, and so on all down the line. The one at the far end will move almost immediately, but if you could slow it down enough, you'd see the nudge propagating along the electrons all down the wire.
    You can look up velocity factors for different types of wire. For instance, in cat 5e network cable, it's about 64 percent of the speed of light.
  8. Raphael Muscarelle
    661
    222
    Actually I was trying to talk about charging not discharging.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
  10. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Though I haven't actually shuffled modules around (or within a pack), I have heard of such and am open to the idea as a whole.
    Please enlighten me with your explanation of the order in which the "modules" should be placed back into a pack and why.
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …reaches for popcorn & suitable adult beverage! :rolleyes: ;)
  12. bisco
    52,777
    cabernet? i'm in!
    Raytheeagle and WilDavis like this.
  13. WilDavis
    2,493
    2,155
    49
    …you're welcome! …come aboard! …pull up a bollard! o_O …help yourself!
    Raytheeagle and bisco like this.
  14. bisco
    52,777
    oh trust me, i just bellied up to the bar :cool:
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Having some Burbon barrel aged Mondavi :).
    A nice afternoon / evening wine;).
    Give it a shot(y).
    WilDavis and bisco like this.
  16. bisco
    52,777
    i may look into that. i was getting bourbon barrel craft beer in florida, and it was very nice.
    WilDavis and Raytheeagle like this.
