HV Battery Compatibilities?
Discussion in 'Generation 1 Prius Discussion' started by cloudstrifens, Dec 18, 2012.
  1. cloudstrifens
    cloudstrifens Junior Member
    2003 Prius
    I just bought a 2003 Prius used from a local dealer, and the HV battery is worn out (according to the Toyota dealership that inspected it). Now the dealer wants 3400 for the new battery and installation, but I found cheaper battery online from a second generation Prius.
    My question is, will the second or third generation HV batteries fit in a Gen 1 prius?
  2. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    The battery cells/packs will, but the Gen 1 uses a different number of packs (17?) and different control electronics and ECU, but people often swap out the bad Gen 1 cells with Gen 2 then charge them so they are balanced.
  3. cloudstrifens
    2003 Prius
    Is there a definitive guide somewhere online or on this forum I can find?
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  5. northwichita
    481
    102
    29
    Wichita KS
  6. bwilson4web
    16,551
    The NHW11 uses 38 modules in 19 pairs. The NHW20 uses 28 modules in 14 pairs. You can replace all NHW11 modules with NHW20 modules and IF you pay attention to charge and capacity, it will run cooler and a long time.
    You might contact ReInVolt in North Carolina. They sell fully rebuilt packs which I switched to in Nov. 2009.
    GOOD LUCK!
    cwerdna likes this.
