HV battery Dead on 2006 Prius HELP!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Sherri167, Jun 5, 2012.
  1. usnavystgc
    3,159
    990
    Tucson, AZ
    Good luck Sheri. +1 on Jeff's advice.
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    Sheri, go ahead and replace that battery with one from a salvage yard. Look on Car-Part.com--Used Auto Parts Market for one at a yard near you. The hardest part about replacing it is removing the trim without breaking it. The dismantling guide is about the best description of removal, albeit there is no need to remove the back seat bottom. Try to find an independent Toyota mechanic to do the job for you. I quote $160 to do it around here if someone brings me a battery -- but I keep the core.
    http://www.eaa-phev.org/images/d/df/Priusdisman.pdf
    wjtracy and dave77 like this.
  3. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Sheri, did you manage to charge the battery full? All grn. bars? H
  4. Sherri167
    Sherri167 New Member
    29
    Fort Worth, Texas
    Since the car is running, can I drive it? Or will this cause more damage? The closest I can find ~at this time~ is 200 miles away. Even if I find a place in Fort Worth I'll be 50ish miles away. I had it hauled to and back from the local Toyota due to not wanting to ruin it or get stuck somewhere.
  5. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    I'd drive it to whoever will do a swap
  6. Sherri167
    29
    Fort Worth, Texas
    HaroldW,
    No I hadn't.
    But I have now! Multiple times, then drops back down. When I started it was on 1 blue bar. If I get it to full greens how long do I continue???
    I do not fully understand the process, I am used to plugging in a charger and leaving it 24hrs.
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Hi Sherri. As long as the car is drivable then it shouldn't hurt anything (other than the battery itself) to drive it somewhere to get it fixed. Just try to plan a route that is not over any mountains or very large hills and perhaps try to arrange it so the drive will be during quiet traffic times.
    Try to drive it easy and in ways that reduce it's need to heavily use the traction battery. Use the following tips to achieve this:
    1. Pre-warm the car in "P" for at least 80 seconds (or until the ICE cuts out) before you drive.
    2. Avoid large hills if possible, and try to get a "run up" at them when you can't avoid them. (Don't use cruise control).
    3. Try to drive at a steady speed. Not too fast and don't try for rapid acceleration or deceleration.
  8. HaroldW
    716
    95
    Hi Sherri. I did a search and it explains how to in the thread called - Is Something Wrong With My Traction Battery? Posted Dec. 9 2009. Here is how it is explained in that post. Warm up the engine first. Press the brake pedal firmly and floor the gas. Don't be afraid to floor it as the ECU will actually take care of the ICE and will regulate the torque in order to produce the desired charging current. Hold it in that state until you reach full SOC. I believe all grn. bars. It will take 2 to 3 min for this process. Good luck, Hal
  9. Sherri167
    29
    Fort Worth, Texas
    I did that, reached all green bars but it took a lot longer than 2-3 min. Then I drove it around without the air on, in my driveway. Not much, my driveway is not long. Shut it off, showed the husband. We just started it, back to 1 bar, we drove it down the street and it started getting to be a bumpy ride like maybe it was going to stop all together so I turned around and came home.
    I did take it apart and take a look at that battery I am learning to hate. ;)
  10. HaroldW
    716
    95
    Yes these type of problems can be frustrating. It does sound like you have a dead cell. Have you checked with Re-involt .com? They repair packs. One member purchased a re-built from re-involt and had his Toyota dealer install it.I believe it set him back $2000 in all. You could try and purchase one from a wreck as well. Hard to find as they are watched for! H
  11. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Worst thing you could have done Sherri. Trying to force charge a dieing battery to full SOC will inevitably result in much of that energy ending up as just internal heat, not what you want to do to an already ailing pack.
    What you want to do is exactly the opposite, drive it in such a way so as to minimize the current (both in and out) of the battery. The tips I gave in the previous post were designed to do exactly this.
  12. HaroldW
    716
    95
    uart on occasion some have lucked out and in fact the force charge actually balanced the pack! Some folks with HCH2 are doing this and having some success. H
  13. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    Sherri,
    I live in the Ft Worth area as well and I do not know of anyone specifically to send you to but, you might give a few of the Independent shops a call and just ask if they have any experience with the Prius Traction battery. It may just be a matter of them having mechanics trained for the work but not having the customers because everyone goes to the dealership. You never know you might just be the catalyst to start a relationship between the local shop and Re-involt. Give these guys a try it might be worth the call:
    In Grapevine: About Us | Import Car Center | Import Auto Repair Grapevine TX | Serving Dallas Fort Worth
    In Ft Worth(downtown): untitled
    Re-Involt has this on their site:
    We are in the process of training installers all across the US and Canada to handle the diagnostics and installation of your hybrid vehicle's battery pack. Call us if you need an installer in an area not listed on our site.
    919-774-3332 Monday-Friday, 7am-5pm EST.
  14. Mike Mc
    88
    35
    Fort Worth
    I just found this one...
    HYBRID SPECIALISTS INC.
    4916 OLD BENBROOK RD
    Fort Worth, TX 76116
    (817) 738-0045
  15. stillageek
    stillageek Junior Member
    52
    There is a place NEAR Fort Worth that works on hybrids. TLS Automotive (Toyota Lexus Scion) has a father and son Toyota Trained (including the Prius) staff. Its truly the father and son who run the shop and work on the cars. Great being able to talk directly too them. They've done minor stuff on my car (water pump replacement, serpentine belt and trans fluid). but it's been fast and economical. Give them a call and tell them Darren Byrd sent you!
    Lexus, Toyota, Scion Auto Repair Euless, Arlington, Colleyville, Grapevine, Southlake
  16. Sherri167
    29
    Fort Worth, Texas
    uart and HaroldW, right or wrong, it's done. So I am going to just have to breath and let that one go.
    Stillageek, MikeMC THANKS! Just what I needed!!
  17. Sherri167
    29
    Fort Worth, Texas
    Oh, Mike MC, I forgot, I have seen this one too. I had Google mapped it and it was S.C.A.R.Y.
  18. Sherri167
    29
    Fort Worth, Texas
    stillageek,
    This place is PERFECT. Just what I have been looking for! I have emailed them and forwarded their info to my husband to call them. Thank you, thank you, thank you!
  19. Sherri167
    29
    Fort Worth, Texas
    TLS Automotive didn't work out. $1500 to replace my one dead cell, 3 mo. warranty. Not interested in installing a salvaged battery for me. I'm better off with a re-involt, installing it myelf, and getting an 18mo. warranty. Sell my battery/cells and recoup some $$.
  20. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm telling you Sherri, replace the one bad cell and save yourself some big $$$$$$$. It can't hurt to try. Your total investment will be about $40 (and time). And...... who knows, it may last a long time. Then you'll be saying "Thank you usnavystgc, thank you" lol :).
