HV Battery died(Death Triangle) , need suggestions
Discussion in 'Gen 2 Prius Main Forum' started by dongfang, Feb 5, 2020.
  1. Cryptogram
    Cryptogram Junior Member
    Indianapolis
    A/C tip:
    Provided the system is still charged and the compressor is not shot look to see If the A/C clutch is failing to engage. There is an easy fix to get it going again. Remove the clutch center bolt (may have to hold the pulley with vice grips) and remove the spacer washer, then reassemble. This will allow the clutch to re-engage.
    Has worked on 2 Prius I have owned.
    SFO likes this.
  2. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    Is there an A/C clutch on a Gen 2?
    SFO likes this.
