HV battery Ecu replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ibblue2, Oct 2, 2020.
  1. ibblue2
    ibblue2 Junior Member
    Illinois
    My Ecu fried the red plug and disingrated 5 pins. Can I install a used unit? Will something need to be reprogrammed? Does anyone repair these units? Thank you.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,225
    5,910
    Columbia, SC
    Yes, the ecus are replaceable with no additional programming required. The best thing you can do is purchase a new wire frame #2 from Toyota for about $60. It comes with the orange plastic frame, sensor harness, plug and new busbars, all preassembled.
    ibblue2 and Isaac Zachary like this.
  3. ibblue2
    Illinois
    Replaced with a used unit from EBay. Same part number and can report that everything is good. Thank you.
