HV Battery fail @ 126K miles
Discussion in 'Gen 2 Prius Main Forum' started by BlackisWhite, Jun 15, 2013.
  1. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I sympathize with the owner, heck I got 2006 with 120k miles it could happen to me too. But the "warning" needs to be taken into context that few have are having the same negative experience. Hence all the excellent marks in the Consumer Reports reliability rankings on the used Prius (last time I checked). Those that have negative experience, there could be reasons, such as clogged batt vents, running out of gas and letting EV batt go to zero charge, etc.
    Now then I am coming to the same conclusion as the OP in Virginia, for somewhat different logic. Why should I buy a Hybrid when Virginia charges me $2000-$2500 taxes/fees more than a equivalent non-Hybrid? And I still have to pay ~$4000 more for the car, and I do still have battery repair failure risk, since Virginia is not CARB they do not offer me 150k guarantee. A consumer is way more ahead buying a hybrid in say Maryland vs. Virginia. Thousand$ less taxes and better warranty in MD. Seems like the non-CARB states ought to ask for their own 150K guarantee.
    PS- Obviously if you are putting on tons of miles per year, the hybrid wins due to massive fuel savings. But what about the 10K miles per year driver in VA? that's where the hybrid math starts to fall apart.
  2. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    A big item on that list is living in a hot climate, where the car is parked in the sun often. A major enemy of the HV battery is heat, and keeping it cool is important. There have been a number of reports of battery failure from the southern states.
    alekska likes this.
  3. BlackisWhite
    BlackisWhite New Member
    Once I decided not to fix the car, my options were certainly limited. I felt I could get a better deal with Toyota, as they can fix the car at their cost, resell the Prius again, and since I'm buying something else, the potential was there for a better deal. The Honda dealer basically offered me a token payment for the Prius. I thought I got reasonable value from Toyota in a trade, basically the KBB wholesale value minus what I thought was their parts cost. At least that is the way it seemed to work out, but again many other people might not have this option.
    JMD likes this.
  4. BlackisWhite
    Was on the site many times, just never felt compelled to join and chat. If I help a few people to think about this situation, then to me it is worth it.
    JMD likes this.
  5. BlackisWhite
    We do live in FL but the car was parked in a garage often, however, the miles were in the heat!
  6. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Nobody likes to be the victim of something breaking. However, if there is an unbreakable car out there, please point it out. I have suffered cracked engine blocks (note the plural) on a Camry. Those are crazy expensive to fix, so the decision was to sell those off after 10+ years of solid service. At the end of the day, I figure I got a good deal. Comparing what I experienced over 10 years compared to GM and Ford issues indicated I made the right decision. If the point of the post was HV battery replacements are expensive, then OK. If the point was buying a Prius is riskier than buying a different car, I'm not convinced with just one data point.
  7. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Believe you are correct about the heat, and that means especially you do not want to park the car in the sun/heat when the HV batt SOC (state of charge) is 100% (all green bars on a Gen2) else you get over-heating of the batt. Also you want to keep your air cond on to keep the semi cool. and apparently dogs in the back seat the hair plugs up the batt vent fan which intake is by the passenger rear door (Gen2 has no filter there) .
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Wonder with an experience like that the next time you buy a car you opt in for the extended Platinum Warranty?
  9. jefe
    jefe Member
    169
    50
    Cary, NC
    Most of the ones I have seen of those only go to 100K miles. I think the better option for the OP is to just do exactly as he said and sell cars before the warranty expires.
    I like the idea of setting up a bank account that has auto draft, that will suck in $30/mo. By the time your car is out of warranty you would have a nice bank to cover any potential problems. If no problems ever happen, when you go to buy a new car, you have a pretty sweet downpayment.
    edit: I say I LIKE this idea, I have never done it :(
    JMD likes this.
  10. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I also sympathise with the OP. I'm at 112 kmiles on a 2005 Prius and live in a hot climate with lots of hills and small mountains, all the worst conditions for the poor battery. Mine is already showing signs of losing capacity, though it's still hanging in there for now. Honestly I've just come to accept that mine could fail any time now, and have even started "babying it" to help nurse it along. (Little things like trying to avoid parking in heat with full 8 bars SOC by letting the a/c blast until it drops to 7 bars before shutdown, and trying to minimize SOC fluctuations by warming up before cold starts etc).
    However fuel is relatively expensive here, and compared to a Camry, which was the main alternative when I got the Prius s/h in 2009, I'm saving $1800 a year in fuel. If my battery lasts another two years (and I think it probably will) then I've saved over $10000 in fuel, which is well over half of the s/h price I paid for the car. To be honest, this puts the Prius in a unbeatable position economically, even if it burnt to the ground and disintegrated in two years time! Why? Because any car would have depreciated by that much (my s/h purchase price minus fuel savings) in that time anyway.
    JMD likes this.
  11. JMD
    3,779
    1,282
    It makes sense. My HOA sends a financial report. They list every item and it's life span and it's estimated replacement cost. Every month money goes toward the replacement of the item fund. Separate fund for repairs.
  12. JMD
    3,779
    1,282
    At least you are preparing yourself for the inevitable.
  13. Britprius
    Britprius Senior Member
    5,194
    1,924
    Herefordshire England
    Uart have you got any information on your battery:- module voltages and internal resistance. It would be interesting to compare with my own.
    John (Britprius)
  14. BlackisWhite
    The Toyota plan was 7 yr and I think 100K miles for what amounted to $1800 more. I declined but I'm considering a new Geico coverage with the same parameters for $34. Over 6 mos with a $250 deductible. That is much more reasonable and still allows a decision to bail prior to 100K. Don"t know if it would cover HV Prius battery though.
  15. BlackisWhite
    Other than transmissions, I've never had issues that cost this kind of money, and while I was aware this could happen, my hope was that the factory price of these battery change outs would come way down over time. That was the implication that I had as I mentioned in my initial note just six months ago another dealer blew smoke up my butt that the cost of these HV batteries was way down (I know, who believes and auto service or sales guy!). I have also had Acura and Honda products that have gone well over 150K miles (200K plus on the Acura) with absolutely no major repairs other than brakes and other things that my family mechanic could fix for several hundred bucks. This would have been roughly $4500. in Prius repair cost in less than 7 months!
  16. JMD
    3,779
    1,282
    I had the Geico mechanical breakdown insurance on my previous car a BMW. It saved me a few times.
  17. JMD
    3,779
    1,282
    I agree based on your experience I would be hesitant to buy another Hybrid.
    I drove a Honda Civic a decade and 250,000 miles and was never presented with a $1,000 repair bill never mind $3,500.
    I would also not repair the car and move on. Perhaps Prius quality improved with the Gen 3
    In California we have 10 years and 150,000 mile CARB HV warranty. Only reason why I bought the car with some confidence. I enjoy the low emissions out of the tail pipe and low fuel charges.
    I have little tolerance for big repair bills. That is why I'll never buy another BMW.
    My wife keeps her cars about 3-5 years and sells them and rolls the equity into the next car. She puts to many miles for a lease to make sense.
  18. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    My daughter just had to put in a new $4000 tranny on her 60k mile GMC Yukon XL' hope you didn't buy one of those!
    JMD likes this.
  19. JMD
    3,779
    1,282
    My father was a GM buyer for multiple decades. Repairs up the ying yang. Finally bought a Toyota Cressida, than a Avalon and never looked back. Based on his experiences I aways purchased Japanese cars except once a BMW which was a money pit.
  20. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Cressida wagon? I got one used when my 84 Camry was stolen. But I have had my share of Fords and Caravans too.
