HV Battery Fan Air Filter Mod
Discussion in 'Prius c Accessories and Modifications' started by Freeekonaleesh2, Mar 6, 2015.
  1. CR94
    CR94 Senior Member
    2,840
    1,246
    Northwestern S.C.
    Right. Even something as coarse as a single layer of typical cheap fiberglass furnace filter material should suffice to keep troublesome big stuff out, and not clog too readily.
  2. Freeekonaleesh2
    Freeekonaleesh2 Junior Member
    38
    TX
    2015 Prius c
    UPDATE 5000 Miles
    Well, had my 5,000 mile Maintenance done today(yes only been 2 Months) at the dealership.
    When I got home I checked the HV Battery Fan Filter I installed from 500 miles, and this is what it looks like after 4,500 Miles.
    Just a slight amount of dust collection and 1 Mosquito.
    No Hole clogging.
    I think the 5000 Mile check is perfect for this setup. (Could go 10K but I'm sticking to 5K.)
    Now I know that less dust is going threw the HV Battery and HV Battery Fan.
    I just washed it with water in my sink, and now clean.
    Let me know your thoughts.
    frodoz737 likes this.
  3. Mendel Leisk
    42,380
    I have been using a piece of vacuum motor filter, virtually since day one. Day before yesterday I pulled it out, not the first time, and swapped in a piece of mosquito screen.
    With the old filter I've been seeing battery temps typically running around 36~38C. I'll see how it goes with this new, much more open mesh.
    I also cleaned the fan and the ducting. You don't need to take the fan right out for cleaning; just reaching in with Q-Tips and then using a little compressed air suffices.
    Before cleaning, not that good of a pic:
    And after:
    We're at 52000 kms, not that much.
  4. Motov8r
    Motov8r Member
    102
    Is his a chronic problem with these fans or a few extreme cases of rolling kennels or Sasquatch owned vehicles?
    iPhone ?
  5. Freeekonaleesh2
    38
    TX
    2015 Prius c
    Well I would consider mine to be a little above normal with dust since I work in New Home Inspections. Very Dusty roads and I bring a-lot of dirt in with my shoes(I have Weathertech floor mats). Though I havent rolled the windows down yet. Im trying to keep the inside as clean as I can. Lol. I do Miss the wind in my hair. Lol
