HV battery filter missing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by OptimusPriustus, Jul 25, 2024.
  1. OptimusPriustus
    OptimusPriustus Active Member
    335
    142
    Finland
    Good day, today i proceeded to clean filter and realized that it is missing. Previous owner probably got bored with it. New filter cost just 10Eur (old style, assembled on top of grille) and should arrive within near days.
    I am just wondering that how important is the venting in cold climate use. Here temperature reach +20deg celcius or more maybe 20 days per year (if lucky). Average yearly temperature +3deg. HV venting system probably never cleaned.
  2. Tombukt2
    Tombukt2 Senior Member
    13,809
    2,504
    Durham NC
    Sounds like HD venting system is hardly ever used if you're in the cold I know here in the winter time in North Carolina where it's 100° in the summer and the fan does run in the winter I almost never hear it so if it's on it's on the lowest plausible setting possible and I don't really run heat in the car I'm heat-sensitive so maybe a tad something on the windshield for the defrost effect and then the car is generally kept cold and the winter time just find natural selection of course no air conditioning needed except when it rains and gets foggy inside Not really that often.
  3. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    The filter also helps keep more dirt, fur, hair, etc., out.
    I also used a foam filter that really helps to keep the dirt and dust out.
  4. OptimusPriustus
    335
    142
    Finland
    Warm cabin air is not utilized to keep HV battery decently warm during very cold weather? The heat from charges/discharges keep battery warm enough even when it’s -20deg celsius?
