HV Battery is Losing Charge Quickly
Discussion in 'Gen 2 Prius Technical Discussion' started by Allen Cobbs, Aug 23, 2021.
Tags:
  1. Allen Cobbs
    Allen Cobbs New Member
    I offered to pay the Hybrid Battery Company's service fee if replacing their battery didn't fix my problem. I am not willing to install a new Hybrid Battery to see if that fixes the problem but I am certainly thinking about a different reconditioned battery or learning how to recondition a used battery myself.
    So, in DrPrius I see three Battery Temperatures. I don't hear the Battery Cooling fan turn on until one of the Temperature reaches about 130 Fahrenheit. Is this normal?
  2. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Hi Allen, You're learning a lot about this car. I strongly recommend techstream in order to get all the codes and details. I'd also suggest clearing any and all codes (after noting what codes you had with techstream) by disconnecting the 12V bat for a few minutes. If you have faulty charging system component(s) techstream should tell you this.
    Do you have access where you live to junkyards with a lot of Priuses? If so you can probably find a relatively low mileage salvage battery and try that. Only problem is that some junkyards think their salvage batteries are worth a lot. With some research on PriusChat you can locate a new battery for not a crazy amount of money.
    I would also ensure that you fully charge your 12 v bat with a charger.
    After that I'd just drive the car until you get codes and not worry too much about indications. If you really do have a bad HV bat it's possible at some point it will discharge too much for it to start the ICE. This can be fairly easily resolved temporarily by making yourself a "grid charger" and recharging the HV bat enough to start the ICE.
    If the seller of the HV bat you have now won't co-operate with you then you have to decide how far you want to fight with them.
    But as you've seen, people on here much smarter than me are not convinced you have a bad HV bat.
    Good luck.
    Allen Cobbs likes this.
  3. Allen Cobbs
    I have tested the 12V Battery several times and it is always properly charged.
    I found a Salvage Yard that will sell me a Hybrid Battery for $89 but I have to go and sort through there Batteries. I found a Hybrid Battery in Lexington for $400.
    I am interested in building a Grid Charger. Where would I find a instructions?
    I have not heard of Techstream. I have heard of Torque. What is the difference and why do you like Techstream?
    I might have a bad Wheel Bearing, Could that effect how my Hybrid Battery is Discharged/Charged while I am driving?
  4. JohnPrius3005
    423
    235
    As I understand it, a "real" test of the 12V bat requires it to be load tested. Most typically have it done for free by autozone
    A HV bat for $89 sounds too good to be true (or too old and worthless) $400 is pretty cheap. In LA I've paid $800 for an HV bat with about 60k miles on it.
    You can search PriusChat for grid chargers. Many use Mean Well LED drivers, which cost around $50, a few short battery cables, a switch (or a diode), and a male 110v plug.
    Techstream is the official Toyota diagnostic software/code reader. As I said above, mini VCI cables can be bought on Amazon, and techstream and a hack for it can be downloaded.
    Anything is possible but I'd say the wheel bearing is unlikely to be creating your issue.
    Good luck
  5. bisco
    52,889
    all 3 of my pri go between 2 and full bars
  6. Allen Cobbs
    It's when it is going down to 1 bar that concerns me. Especially the two times it stayed on one bar long enough to throw the Red Triangle and the P3190 code (again I have only received the P3190 when the Hybrid Battery has gone below 1 bar (I saw an SOC of 39 % yesterday).
    FYI - I did the DrPrius Full Battery test yesterday and it failed;
    Load Testing - upper voltage: Warning Poor balance block #1
    Load Testing - bottom voltage: Warning Poor balance block #1, #2
  7. bisco
    52,889
    yup, that's a problem. i can't understand why you're not getting a code for those cells though
  8. JohnPrius3005
    423
    235
    Hi Allen,
    Yes, I agree with you and bisco after this test result. You might find techstream gives you more in depth information. But it seems you do have a battery issue as you've said all along. Your challenge is clearly what to do about it. If the seller creates roadblocks to their addressing this then your options are somewhat limited: you can pressure them further (your transaction with them will not be good publicity for their company), you can try to "refurbish" the battery yourself (you might find replacing blocks 1 and 2 with exchange blocks works, or you might just have bad connections, although any type of refurb is a temporary measure), you can replace the battery with new or another refurb. PriusChat is loaded with options on what you can do. The most conservative, long term solution preferred by some is to replace the HV bat with new. If you do this you can likely sell this old bat for a fair amount because many others are willing to do shorter term refurbs. I don't believe there is any magic solution - ie one which is long term, cheap, easy, and effective. Of course you can also just keep driving the car until you get other codes and more significant failures. Good luck.
