HV battery Kit Installers in Southern California
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SandNerd, Mar 19, 2022.
  1. SandNerd
    SandNerd Junior Member
    Southern California
    I apologize if this might be out of the scope of this forum, but I’m finding few and not so good options for my tight-budget predicament.
    I basically need a place/person that’s open to replacing my HV battery modules with NPB kit or with modules from a new Gen 2 pack (as I recently discovered that was an option!).
    I already researched some of the places close to me (LA,OC), majority won’t do it while the rest would charge +$500 for this.
    Any suggestions or advice would be highly appreciated.
    P.s. I live in an apartment building, no garage, no equipments, and my car DIY skills never went beyond tire change.
  2. JC91006
    16,674
    8,519
    I'm curious what you would feel is a fair price to pay for this service you're looking for? $500 is about average I think for someone to take apart a battery
  3. AzusaPrius
    AzusaPrius Senior Member
    2,137
    904
    Im not sure if you can use gen2 modules on newer gens but you might be able to use newer gen modules on gen2.
    Someone who knows about gen2 may chime in and give a better answer.
  4. JC91006
    16,674
    8,519
    The ,modules are the same from Toyota. Just the case is different. It's strange why Toyota charges more for the Gen3 pack vs Gen2. So basically you just transfer the modules from 1 pack to the other. This is the same with Camry Hybrids
    SandNerd likes this.
  5. Mendel Leisk
    40,586
    Yeah bit of a hornet's nest? Especially if you expect installer to take full responsibility, for a smooth/successful install..
  6. AzusaPrius
    2,137
    904
    Well now that I think about it, I guess you can use gen2 modules.
    I remember my pack I got in my car when I bought it had already been replaced and had modules from 2005/2007 in it.
    My pack was older than my car at that point but now I am good with the Lithium battery from Dr. Prius.
  7. JC91006
    16,674
    8,519
    How much was the lithium kit?
  8. AzusaPrius
    2,137
    904
    For gen3 it is like $2100 but if you use my link you can save some cash
  9. JC91006
    16,674
    8,519
    Followed your link and found a quote on there.
    "First time hitting 3 miles on pure EV mode, incredible, car drives like new and accelerate faster then new. Thank you Dr. Prius
    Larry Chen, Temple City, CA"
    I'm a bit skeptical about this, 3 miles with EV on our Prius in Temple City CA? Where the heck can he go that far with speeds under 25mph?
    Anyways, good additional option. Just not sure of the claims on the site
  10. AzusaPrius
    2,137
    904
    Yea your miles may vary as you can get 6 or more miles in EV with it.
    I need to record a video in EV mode and show how it does extend the mileage in EV
  11. JC91006
    16,674
    8,519
    Back to the OPs topic.
    I would be willing to help you with this swap. But what you're describing will take some time to remove and disassemble. It's not straight forward as a regular battery swap.
    You would most likely need to do this at a location other than your apartment building. Downtime would be a few hours
    Paul E. Highway and jzchen like this.
  12. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Availability? Meaning did you already buy a battery/do you have the replacement?
    REVVL V+ 5G ?
  13. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    right on! (y)
  14. SandNerd
    Southern California
    Nothing yet. I wasn't in a hurry since the car continues to operate (with regular OBDII resets). The car has less than 98k miles on it so I'm assuming it's only 1 or 2 cells causing the issues. It's getting me around 35 MPG now though, and with these gas prices, I decided I had to bite the NiMH bullet.
    I'm looking at the Tustin Toyota's Gen2 battery as it seems to be the lowest price in the area ($1,847.35 w/ taxes after core charge return) and I'm able to buy it online. Only issue I'm afraid of with that option is that they'd notice the modules are from Gen 3 and would refuse to return core charge. However, since I discovered that other installers are doing in it in the area, I'm hoping that won't be an issue.
    I just found this core charge policy but it's old and doesn't say much http://cleandealer.com/documents/Warpol910_TOY_rev2-2013.pdf.
  15. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    Lol, it only takes two hours... I charge a bit under $100 to do it... It's astonishing how much people expect to pay to do very simple nuts & bolts work on a car.
  16. AzusaPrius
    2,137
    904
    Go with PriusCamper you can not beat under $100 to do that.
    PriusCamper likes this.
  17. JC91006
    16,674
    8,519
    Are you talking about a gen2 prius? It’s back breaking work
  18. JC91006
    16,674
    8,519
    They don’t care what you give back to them, as long as they are original modules.
  19. PriusCamper
    12,064
    4,896
    Not really back breaking work at all after you've pulled packs more than four dozen times... Takes 15 minutes to pull the pack, 45 minutes to build out the new pack, 45 minutes to install pack and put car back together and 15 minutes to a 1/2 hour for unexpected hassles. I got references of people I've done this for if you live near me...
  20. PriusCamper
    12,064
    4,896
    But they aren't gonna get out a magnifying glass and confirm the serial numbers on each of the 28 modules, so as long as they look like original modules you'll be fine.
