HV battery maintenance suggestions
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DenToyPri05, Jan 13, 2015.
  1. Jim Porta
    Jim Porta Junior Member
    86
    17
    Louisville, KY
    Question: Toyota attempts to keep the traction battery between 20% and 80% for a long useful life. How does max charging to 100% and discharging to around 0 help other than the weakest cells?
  2. DenToyPri05
    DenToyPri05 Junior Member
    118
    24
    Denver, Co
    Shop called with battery assessment update: it's at about 45-50%. So...this explains so much!
    Then...I was all ready to buy a grid charger. I reread the responses here and other places and talked to other folks.
    Totally slipped my mind that I need to plug it in! I really like the idea, but I live in an apartment with a detached garage. I thought there was an outlet available, but there is none. Getting the hv battery. ...my oh my...
    Still a cool car.
    I'm researching sound deadening. Looks like fun.
  3. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    Due to being repetitively cycled within the same range, all of the cells in the battery pack will build crystal formations that reduce usable battery capacity. By cycling the battery above and below this memory affected range, you can break the crystals down and regain lost performance and capacity.
    Further, due to the vehicles limited usable battery range, the car cannot correct cell imbalances on its own. Only by very slowly and safely charging the battery to max capacity (while cooling it) can you rebalance the cells with each other.
  4. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Can’t you just steal electricity from lighting or similar?
    jeff652 likes this.
  5. DenToyPri05
    118
    24
    Denver, Co
    I'd need a time traveling DeLorean with a working flux capacitor.
    jeff652 likes this.
  6. dolj
    dolj Senior Member
    8,645
    4,395
    Wellington, New Zealand
    Lighting, not lightening. LOL.
    jeff652 likes this.
  7. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Take me with you. There are some things I need to fix in 1980. :cool:
  8. jeff652
    607
    624
    Idaho
    In all seriousness, we have customers who (legally) use a light bulb socket converter to get power in their carport/garage. The charger never draws more current than a 75W light bulb, so it is well within the capabilities of a typical lighting circuit.
  9. DenToyPri05
    118
    24
    Denver, Co
    the mind of a prius owner is far far advanced. i interpreted correctly. ohhmmmmmmm....
  10. luisneto
    luisneto Junior Member
    aveiro
    i´m i readind this correct? your charger charge the all series and not balance one by one??
  11. dolj
    dolj Senior Member
    8,645
    4,395
    Yes, that is correct. To do this most here are using the Hybrid Automotive Prolong charger.
    As an aside, your location is Aveiro, Portugal?
    Raytheeagle likes this.
