HV battery module busbar nut torque value
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Jan 20, 2020.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    They are 8mm, but for all intents and purposes, a 5/16 is identical (enough) to an 8mm
    Please remember, the torque is measured using INCH-pounds, not foot pounds. 48 inch-pounds.
    That level of torque shouldn't cause any problems with rounding off corners.
    R_W and Mendel Leisk like this.
  2. Mendel Leisk
    42,352
    This video (and they seem to know their stuff) says the sockets for a battery overhaul include an "eight, ten and twelve mm".
    My first thought was it would be 8 mm. As you said, 5/16" is just a hair less than 8mm, still maybe your best option?
    R_W likes this.
  3. R_W
    R_W Member
    82
    25
    Maybe my 5/16ths are so old they're a bit stretched. As I told my wife, if I were taking out an alternator or something, I wouldn't have even noticed it was a hair too large, but I'm being super careful with the battery.
    Tomorrow, I'll pick up an 8mm because I should have one anyway. I'll use whatever's the tighter fit.
    As always, many thanks
    Mendel Leisk and Raytheeagle like this.
  4. LukUsc
    LukUsc Member
    69
    26
    Poland
    There is a bug in the video - the torque should be 48in lbf / 5.4Nm. not 60 as they say?
    Or did I mix up something?
    By the way - there is also an error in the manual.
    They write once in. lbf, And next to it they write ft. lbf, As if they were the same - be careful ;)
    I see now, that it was already about it above. Sorry :)
    #24 LukUsc, Aug 4, 2020
  5. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,603
    Taylors, SC
  6. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Someone knows the torque specs of the bolts that hold the hybrid battery to the car? i need to know before replacing my 2012 Prius C hybrid battery.
  7. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    The Gen 2 manual has these mounting bolts labelled as requiring
    28 n*m, 286 kgf*cm or 21 ft*lbf
    They are identical fasteners, so it should be safe to assume the exact same requirements for Gen 3.
  8. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    I see, thank you very much.
  9. Sonic_TH
    575
    96
    Puerto Rico
    2016 Prius c
    Hi there, my Prius C gave me the P0A80 code, in the Prius C there is a piece of metal that holds the back seats in place, it needs to be removed in order to gain access to the hybrid battery. Any information about the torque specs of the bolts that hold that piece of metal in place, where the back seats go?
  10. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    This video is incorrect. Although it had some good info he gets that part wrong.
