HV battery Oil pan pre-heating in winter
Discussion in 'Gen 3 Prius Main Forum' started by Abarnabe, Feb 16, 2025.
  1. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Third planet from the Sun
    Abarnabe likes this.
  2. Mendel Leisk
    41,255
    I’ve got my previous one (wiring shorted) around somewhere; I’ll try to find and measure with a caliper, in the morning.
    #22 Mendel Leisk, Feb 17, 2025
  3. MAX2
    MAX2 Senior Member
    1,436
    487
    101
  4. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    From Chat GPT :)
    In a gasoline hybrid car, both oil temperature and engine temperature play important roles in fuel consumption, but engine temperature is typically more critical for fuel efficiency. Here's why:
    1. Engine Temperature:
      • The engine needs to reach an optimal operating temperature (usually around 190-220°F or 88-104°C) for fuel to burn efficiently. When the engine is cold, it runs less efficiently, consuming more fuel because it uses a richer air-fuel mixture to prevent engine damage.
      • A fully warmed-up engine operates more efficiently, reducing fuel consumption and emissions.
    2. Oil Temperature:
      • While oil temperature is also important, it mainly affects engine lubrication and reduces internal friction. If the oil is too cold, it may not flow well, leading to increased friction and wear, which can impact fuel efficiency in the long term.
      • Oil temperature needs to be at a certain level to provide effective lubrication, but it’s generally not as critical as engine temperature for immediate fuel efficiency.
    In a hybrid system, the electric motor can assist during colder engine temperatures, which can help reduce the fuel consumption penalty until the engine warms up. However, once the engine reaches its optimal operating temperature, it can deliver maximum fuel efficiency, making engine temperature the more crucial factor for day-to-day fuel consumption.
  5. Mendel Leisk
    41,255
    Apologies, I've tidied up and put it away somewhere. Will keep an eye out.
    Here's the part number for the more recent one I got, purchased/installed in Oct 2019, obtained from local dealership for $90 CDN:
    PU140-00905
    Note: it is currently subject to recall by Toyota Canada, apparently due to possibility of wiring shorting out. I've contacted local dealership service manager about this. That was Jan 4th of this year, and apart from a little back-and-forth, no resolution. He's been in touch with Toyota Canada...
    I've heard one thing they'll do for you is cut off it's plug... o_O
    Anyways, the extension cord I'm using with mine plugs into a wall-mounted outlet box with a breaker. It's effective, kicked-off one time when I cut my hedge trimmer cord. :)
    #25 Mendel Leisk, Feb 17, 2025
  6. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    Thank you Mendel and Max 2.
    Did the wire insulation melt near the block heater or near the plug? Melting is usually caused by undersized copper wires, copper is very expensive and they try to save on it.
    Today I laid down some cardboard boxes on the floor, I removed the underbody cover and measured the depth of the hole, it' s 70mm I couldn't stick a caliper in there to measure the diameter, but I think all block heaters for jap cars use a standardized size, so 18mm, I attached a screenshot of a Mitsubishi forum .
    Further I found and ordered standard heating cartridges of same size and rated 380 W 230v, they are sold in pairs, 22 euro including shipping.
    https://a.aliexpress.com/_Exuv8OY
    The heater is 85mm long, the first 10 mm are just contacts sinked in the ceramic insulation and protected by metal case I'll make a clip with a metal strip and a small hose clamp to fix it to the cylindrical cartridge and click it in to the right position on the engine, similarly to the genuine one, I'll apply some termal compound in between.
    I also ordered a few waterproof plugs and sockets for the wiring .
    Looking forward to delivery and assembly.
    https://a.aliexpress.com/_EIsVRV6
    #26 Abarnabe, Feb 17, 2025
    MAX2 likes this.
  7. Mendel Leisk
    41,255
    The Toyota heater element has a clip at the top, that secures it. I would persevere for a while, trying to find the official one.
    The electrical short was right where the wire connects to the heater element. I'm thinking it might have been pulled too taut during install. Could be due to the heat of the element as well.
    Maybe significant: there was no evidence of heat transfer grease on the failed one, not even staining from grease long baked off over the years. Could be the dealership installers never put on the grease...
    MAX2 and Abarnabe like this.
  8. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    ok, I think it wasn't the copper wire thickness the issue here, but the element heat.
    If the wires were insulated with fiberglass cloth or silicon instead of standard pvc maybe the short was avoided.
    I see DEFA uses a different design where a 10 cm rod between heater and wire dissipates part of the heat and keeps the wires away from each other.
    I think the missing heat transfer grease is indeed responsible for making the wire's life even worse.
    I'll see if I can find some extra fiberglass sleeves for mine like this upload_2025-2-17_21-29-15.jpeg
    #28 Abarnabe, Feb 17, 2025
  9. Leadfoot J. McCoalroller
    8,056
    7,537
    Pennsylvania
    2018 Prius c
    The whole key to burning less fuel to heat your engine is to use an energy source other than gasoline.
    If you use gasoline to make electricity while you are driving in order to charge a battery so you can use the electricity later to heat the engine on the next cycle, you're really just adding weight and complexity while still getting 100% of that heat from gasoline.
    And you are wasting extra gasoline doing so, to cover the charging inefficiency of the HV battery.
    If you want to reduce the use of gasoline to heat your engine, you need to get that heat energy from somewhere else altogether.
    Get a block heater (or a tank heater, they are popular in N. Europe) and plug it into mains power to achieve your pre-heat.
    All this other stuff is just time-shifting the usage of gasoline.
    #29 Leadfoot J. McCoalroller, Feb 17, 2025
    Abarnabe, CR94 and MAX2 like this.
  10. Mendel Leisk
    41,255
    One spin-off benefit of the block heater, which came in handy for me today: wanting to wash our ‘10 in the driveway, without starting it up for the move from garage, I plugged in about 90 minutes early. Then when starting, I was able to have EV mode.
  11. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    Still waiting for the parts to arrive, but what about engine block and oil pan insulation?
    I See BMW claims their insulation speeds up warm up, slows down cool off, lowers emissions and fuel consumption.
    Would it be beneficial on our engine? I found this 10 mm foam with a layer of aluminum foil,
    the idea is to cover front, back of engine block and the timing chain carter.
    It would be an addition to the grill block, and could be removed in summer like a diaper
    https://a.aliexpress.com/_EylncS8
  12. Leadfoot J. McCoalroller
    8,056
    7,537
    Pennsylvania
    2018 Prius c
    Probably past the point of diminishing returns, at least for NL winters.
    If you are regularly starting the car at -40C or colder, then those extras become worthwhile.
  13. rjparker
    rjparker Tu Humilde Sirviente
    10,054
    6,221
    Texas Hill Country
    There is an under engine cover that has insulation which came on my gen3.
  14. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    installed block heater, I went through different kind of clips, at the end I preferred to insert it all the way in and and block it with an old bike spoke.
    The undervoltage circuit failed, I've ordered another one.
    The oil pan heater smokes and burns, it switches on and off once too hot, so I opted to remove it.
    Installead instead an oil pan thermal insulation, that I' ll remove in the summer.
    #34 Abarnabe, Mar 9, 2025
    MAX2 and StarCaller like this.
  15. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    Are the heaters burning because they are not tightly fitted to the sump body?
    Sump insulation is also a good option to keep warm during winter trips.
  16. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    Yes, correct, it doesn't adhere to the groves, I have tried also to apply it on the vertical aluminium wall of the carter, there you have a nice flat surface, but still there is a shallow grove.
  17. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    The block heater doesn't smell and fits well, only I had to decrease the diameter from 18 to 17,5 mm with sand paper, here are 2 different clips, made out of a bike spoke.
    The first clip is fixed to the heater body with a hose clamp, 1 cm of the heater remained out of the engine block causing the contacts and the silicon sealant to become so hot I couldn't hold my fingers on it.
    Since the contacts are very close to the hybrid system wire harness I decided to go for a different solution.
    The second clip allows the heater to go all the way into the engine block, this time the contacts and the red sealant are cool and I can hold my finger on it. I fixed a bike spoke to a hole with a bolt and made a 90 degrees corner to hold heater in position.
    I also applied a heat sink compound on the heater.
    The cost of the heat element was 22 euro for 2 pieces, but If I had to do it again I would search for a 17 mm diameter one with a lengt of 80 mm or even 70 mm so that it can be held in place with a C lock ring or a c shaped piece of spoke.
    I applied high temp silicone sealant on the wires and slide an extra glass fiber hose on each pole, plus grounded the power cable to the engine block on a EGR screw
    #37 Abarnabe, Mar 10, 2025
  18. Abarnabe
    Abarnabe Member
    168
    99
    Netherlands
    I connected thee block heater (350W) to the HV battery.
    The battery dropped from 60% to 20% or from 240v to 200v in 70 minutes.
    The temperature went from 9° to 30° C.
    According to Prolong it is safe to discharge the battery to 196v with a load of 400w and now I'm charging it back at at least 60% with my HV grid charger.
    I can definitely say that the HV battery is insufficient to warm up the engine block, but it was a nice try
    vvillovv likes this.
  19. ASRDogman
    ASRDogman Senior Member
    7,526
    3,891
    Block heaters were designed to be plugged into a 120acv wall outlet..... not a hybrid batter.
  20. MAX2
    MAX2 Senior Member
    1,436
    487
    101
    The high-voltage battery has modules of 6.5 Ah.
    The hybrid uses the battery in the range from 40 to 80%. This is only 2.6 Ah.
    The maximum useful power that a new high-voltage battery charged to 80% can give without problems for its life cycle is about 500 W * h.
    This is very little for any significant heater.
    A 2 kW heater will suck the energy out of the battery in a quarter of an hour.
    Considering that the batteries are usually not new, the energy given off will be significantly less and there is a risk of going to the store to buy a new battery.
    Use devices for heating the car intended for the home electrical network.
    CR94 and Abarnabe like this.
