HV battery out, 5-th door locked, please help!
Discussion in 'Gen 2 Prius Technical Discussion' started by sofiawizz, Jul 9, 2016.
  1. sofiawizz
    sofiawizz New Member
    Hello Prius specialists! I started yesterday the procedure for changing a cell in the HV battery and everything was as described in the youtube videos, except that today when I wanted to continue, I cannot open the 5-th door! I closed yesterday evening and today I cannot open it! The battery is out, the other doors can be open. Please help!
    Thank you.
  2. JC91006
    16,673
    8,518
    There is a manual lever on the inside of the hatch, right in the middle where the hatch normally would latch on when shut.
    If everything in the back is removed, you should be able to see it easily
  3. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    51,155
    welcome to priuschat! what he said.^^^
  5. sofiawizz
    Thank you very much! It opened easily. If you are curious about the mileage, my Prius 2005 has 221,800 miles, just yesterday I decided to change a cell in the HV battery by myself, after running around 2 months with a bed cell. Details: I ran twice around 140 miles without stopping with bad battery. After 7-8 miles the indicator for charging the battery stooped working, but the car was running (maximum 50 MPH). I think that the computer prevents the Prius to run only on gas (like non-hybrid vehicles), is it true?
  6. sofiawizz
  7. bisco
    51,155
    well, you do need a functioning hybrid battery to keep starting the engine. that's pretty cool, i hope it works out well for you!
  8. JC91006
    16,673
    8,518
    The computer puts the car on limp mode, it cannot run only the gas engine without the hybrid functions, it'll go in limp mode when the hybrid functions fail
