HV battery repair options advice?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wddanie, Sep 5, 2017.
  1. JC91006
    16,929
    8,639
    What business model? What does it say
  2. wddanie
    wddanie Junior Member
    58
    Atlanta
    The Forbes article covers how the author loved his 2005 Prius until the battery started failing. He was shocked of quotes of 3-4K$ from dealers to repair it and discovered a local rebuilder who swapped out bats for $800, which he choose to purchase. The author explains that Toyota ought to offer rebuilt packs for ~800$ to preserve Prius customer good will.
    https://www.forbes.com/sites/tonybradley/2014/04/09/replacing-a-dead-prius-hybrid-battery-doesnt-have-to-cost-thousands-of-dollars/3/#7288ec5d2bd1
  3. wddanie
    58
    Atlanta
    I wondered what charging approach you used to get your modules to 7v?
  4. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Well I'm not surprised by the fact Toyota do not offer that given the cost, effort and reliability issues around trying to match crappy modules with equally crappy modules. The only reasonable business model option, from a Toyota perspective, is to replace all modules with new ones, which is what they do.
    Whether the price for that is congruent with the service is a question for market forces.
    I wonder how many people who have gone down the rebuilt route to have regretted that and wished they had just replaced the battery with a "Toyota new" in the first place.
  5. dolj
    dolj Senior Member
    8,633
    4,385
    You are correct, a difference of 1.2 V or more would point to a failed cell.
    Given the voltage spread, I'd say you have a greater than even chance to just use a grid charger to do the 3 cycle reconditioning.
    The fact that you have thrown the DTCs does mean that the Delta V under load is going outside of spec. You may be one of the lucky ones to have caught it in time.
    #25 dolj, Sep 6, 2017
    jadziasman likes this.
  6. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    My Radio Shack Multi Meter read 7 VDC on every cell except one 6 VDC. IMG_2237.JPG
    For me a charging cycle is driving up 4144 ft , Tejon Pass elevation, with cruse control at 70 mph and air conditioned to 71 degrees (drains the battery and keeps battery cool ) I then recharge down the other side of the hill shifting to B mode when the battery is full.
    iPhone ?
    m.wynn likes this.
  7. Paul Schenck
    524
    307
    Fresno, California
    It's really like holiday lights, one bad cell and the entire bank doesn't function. Remove the the cell creating the resistance in the series and the entire bank is restored. Batteries in a series perform like a chain the weakest link will fail first. I think with thermal imaging you could easily see which link/cell was going to fail, as it would generate more heat. Keep using the chain and eventually every link will be so warn it's time to replace it, though with my Prius at 430,000 miles I'm going to go down the rebuild road this time and let you know how it goes. I was scared about it, though since I had a spare battery from a 2005 Prius of known 80 K mileage I decided to try it. I had originally replaced the battery pack at 290,000 miles with a $3000.00 Exchange from Toyota, thinking I was gonna drive the car forever! Then at 390,000 miles the engine wore out. $1000 got me a salvaged 2006 with 100,000 miles. The engine and transaxle swap was a joy to do in my own garage. Upon start up it threw out all kinds of codes and I ended up taking out my $3000 battery and using the salvaged battery. It turned out the codes were caused by a damaged throttle body not a bad battery. I swapped it out with the older one and all the codes cleared up. Months later, I Sold my $3000 battery for $1500 installed, getting a 2005 80K battery in exchange, which supplied me with the spare cells to do my rebuild.
    iPhone ?
    m.wynn likes this.
  8. PriusWise
    PriusWise New Member
    Milwaukee, Wisconsin
    Doug, another option would be to buy the Prolong unit, and to recover your cost, offer to condition other Prius owner's batteries at $150. That would pay for a new battery, if need be, in no time.
    Dan, 3rd gen from the sun
  9. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Battery conditioning via grid charging is a periodic maintenance process usually monthly but even more frequent for really weak batteries.
