HV Battery Temps Hitting 116f
Discussion in 'Gen 3 Prius Technical Discussion' started by priusCpilot, Aug 15, 2017.
  1. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    I have a Prius C. Outside temps can hit 100+ and after parking the batter temps can be 116. Even parked in the shade? Also in stop and go driving they go high 110 and drop slowly? Temps are from the center probe on shown on a SG.
    I started to put the battery on speed 6 now. I know others have the same temps but don't know it since they don't have a SG under the same conditions.
    51,148
    a/c on full blast?
  3. priusCpilot
    663
    210
    LA
    Yes I do drive with the AC on and also I said it for middle and lower events so that down some cool air goes down below to where the event is to the battery.
  4. davecook89t
    davecook89t Senior Member
    1,076
    810
    Washington State, Florida
    Four Touring
    116 F? Pshaw, that's nothing. 58.4 C (137 F) Temp on HV Battery per Torque Pro | PriusChat
    More than 5,000 miles later, my car still runs like a top. As @edthefox5 said, these are tough little cars.
  5. bisco
    51,148
    the do suffer in the south though. unfortunately, it's not when you're driving as much as it is the heat soak of parking in the sun all day. great for solar panels though.
    davecook89t likes this.
  6. priusCpilot
    663
    210
    LA
    Wow never went that high. I did see 122 which came down to normal levels after parked.
    Now I run the fan speed 6 full time. I like keeping it as cool as possible because shortens battery life.
  7. davecook89t
    1,076
    810
    Four Touring
    I feel the same way, I would like to keep it as cool as possible. I understand the fan speed can be controlled using a Scan Gauge, but I do not believe it can be done with my Torque Pro app. In any event, it is comforting to know that the battery will survive the occasional overheat incident.
  8. bisco
    51,148
    makes you wonder why toyota doesn't have the fan speeds come on at lower thresholds.
  9. davecook89t
    1,076
    810
    Four Touring
    Maybe running at a lower fan speed saves a fraction of an MPG? I'm learning to trust the judgement of the folks who designed the car, but sometimes I think I would have made the safer choice.
  10. bisco
    51,148
    they have to pony up for the 10/150 warranty, but not in too many hot states.
  11. davecook89t
    1,076
    810
    Four Touring
    You're saying they might have had a different design strategy if more southern states had adopted the CARB standard? Interesting.
  12. bisco
    51,148
    it's possible. the whole southern border is non carb, and most all the the central states. so they only have to worry about socal.
  13. davecook89t
    1,076
    810
    Four Touring
    And unlike the East Coast and South, night-time summer temperatures are generally much more tolerable even in Southern California, so the battery has some chance to cool off.
  14. priusCpilot
    663
    210
    LA
    I thought the same? The only conclusion I came up with were these?
    1.) Fan noise might annoy a hybrid owner?
    2.) To get a tiny bit more MPG but when the bat runs real hot MPG falls?
    3.) Premature fan wear that may fail during warranty which might be more of a risk compared to battery??
    Anyhow, all three are not an issue for me. Prolonging battery life in hot climate is my top priority.
    I have no pets and have 90k miles. Wounder how dirty the fan might be?
    bisco and davecook89t like this.
  15. bisco
    51,148
    probably not very, but worth a look when you have a chance. check the intake grille, that's easy.
  16. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    Check out this thread. 240 degrees!!! | PriusChat
    116 degrees is well within the expected range for normal operation.
  17. priusCpilot
    663
    210
    LA
    Thanks! This thread is for mg2 temps which I have seen 270f while towing my jetski. I'm not concerned with that as much as battery temps. I also switch to Redline oil in the trans to protect it further since it retains very good viscosity under high heat.
  18. priusCpilot
    663
    210
    LA
    Running the fan on high has done the job. The bat now runs in the 90s with AC on and hot ambient temps.
  19. Mendel Leisk
    40,580
    Is it possible you're over cooling?
    Driving on cool evenings with windows half rolled down and monitoring the middle (hottest) battery sensor, ive seen 35C. This would seem to be by design, Toyota's ok with this.
  20. priusCpilot
    663
    210
    LA
    No not in Summer that's for sure. Today it is 110f. When it cools down for no AC I'll turn off the fan.
    So far from the middle sensor I can seen 122F but no more.
    Here is why I think Toyota is OK with the higher temps.
    The high temps will not kill the battery immediately. It will make it threw threw warranty but will shorten the life. I plan on going at least to 300+k miles without replacing the bat. I'll have to see how the fan looks some time next year. Also going to install a tool to balance the cells.
