HV Battery Temps Hitting 116f
Discussion in 'Gen 3 Prius Technical Discussion' started by priusCpilot, Aug 15, 2017.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Temp was 111 today where I live, the fans were howling at 9am til 4:30pm nonstop parked in no shade with solar panel kicking nice person. Start engine and minute later, ICE goes off. Gear set to reverse and then ICE came back on quickly. Drove for 6 miles; 1 mi HWY + 5 mi under 45 mpg NO FAN/AC all windows down w/sunroof fully open. ICE never went off, EV never lit up. Temp was too high? I waited til 7:30pm drive to the store, same result but this time I turned on the AC recirculate, 5 minutes later EV lit up and HV batter was charging again. Dam summer weather, cant wait for it to go away. Not even solar + fans kept it cool enough to drive w/o AC on.
    52,777
    you definitely need the a/c to help cool the battery down.
  3. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Running the AC is a must as mentioned by others.
    Also that bat was cooking up good. Better get a SG and run the fan like I am. I'm running 90s now.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    that i already knew, driving with sunroof open is what its all about, even its its hot like hell
  5. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    What do you mean by that?
  6. priusCpilot
    663
    210
    LA
    The bat takes in air from the cabin so if the AC is not on AND set to for the middle and lower vents on the Prius C. Then cool air won't go to the bat intake behind the drivers seat and below.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I meant the comment above. My bad for not being specific heh.
  8. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    Guessing the reason for holding the fan speed down until its gets really hot is probably the same reason video card manuafcturers do it for computers. To prevent excessive noise. Most people don't want their computer to sound like it's about to take off like a helicopter when they're just surfing the web or playing a little browser flash game. Toyota might think that the cranking fan all the time might make people feel like the car is struggling.
    priusCpilot likes this.
  9. priusCpilot
    663
    210
    LA
    Im using the scangauge to turn the fan on full speed 6. This is keeping my bat in the 90s F and well worth it!
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Gotcha, you can modify the fan speed RPMs. I'm old fashion when it comes to fan noise; faster RPMs means cooler temps and louder it is. Who cares how loud it is, loud and proud.
  11. Mendel Leisk
    42,268
    What's next for you guys, lowering your engine's running temperature? :rolleyes:
    I seriously wonder: could you be pushing this too far? If the battery settles in around 35C, on cool evenings, once the everything's warmed up and stablized, just maybe it's by design?
    m.wynn and Raytheeagle like this.
  12. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    I also wonder if pushing the fan hard all the time could overwork it to the point of early failure:cool:.
    Something to consider;).
    m.wynn likes this.
  13. priusCpilot
    663
    210
    LA
    We were 115f here so way to hot here in So Cal.
    If the car keeps bat temps below 100f I would be ok with that but I see 122f when the car was parked in the shade. At those temps the car turns the bat fan on full until about 115f when starts goes down to a lower speed. I'm going to run my fan full on until It cools down here below 90f and see how it goes.
    Buying a fan is cheap compared to dealing with a bat. I must get 300-400k miles on the bat or I won't be happy.
    m.wynn and Grit like this.
  14. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
    I had one experience with 63 C (145 F), just a lot of hills and stooped the car at the bottom with battery full, the fan does not run when car is OFF. Going back into the car one hour later was an unpleasant surprise, especially going back up the hill without the help from the battery.
    Car will try not to use battery when it's nearing 50 C (122) or over that, from around 45-50 C battery will stop charging at around 70% SOC even if you do serious downhill regen but other than that you get normal "boost" from the battery. Bellow 45 C car operates normally. In freezing temps it also "discounts" the battery, I have observed this below -15 C or around there somewhere.
    priusCpilot and Mendel Leisk like this.
