HV Control ECU 2004 Toyota Prius
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Nov 2, 2017.
  1. TwoPriusInTenn
    254
    66
    Tennessee
    Would anyone happen to know what the letters GIVA, GIVB, GIWA, GINV, GIWB stand for on the wiring of the HV Control ECU Connector and the inverter connector?
    #1 TwoPriusInTenn, Nov 2, 2017
  2. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    Aren't they just the names given to pins 2, 3, 18, 16 and 19 on the I-10 connector and pins 34, 33, 32, 23 and 31 on the H-15 connector?
    The V/W in the name most likely relate to the generator phase V/W current respectively.
  3. TwoPriusInTenn
    254
    66
    Tennessee
    I finally wrapped my head around that diagram. Everything on the volts and ohms test(s) check out. Looks as though the inverter converter has gone bad.
  4. TwoPriusInTenn
    254
    66
    Tennessee
