HV coolant pump replacement, and it's part #
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sciencekit, Oct 10, 2011.
  1. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    Does anyone know the part number of the old HV coolant pump vs. the part number of the replacement HV coolant pump under the Campaign?
  2. Patrick Wong
    18,200
    6,493
  3. sciencekit
    76
    Norfolk, VA
    Thanks! I should have searched under the LSC A0N. Guess I will just take it in and let them perform the replacement.... even though I had to pay for it myself three years ago. I was looking for a way to identify the pump part number on the invoice from that repair. However, if it is the same number then I cannot tell.
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    You have until 11/30/2013 to have the dealer replace it. Most likely you already have the improved part. I wouldn't be in any rush to get the job done.
  5. Patrick Wong
    18,200
    6,493
    If you have the invoice from your repair 3 years ago, then you should be able to claim reimbursement if you write to Toyota. I recall that the LSC customer notification letter has a provision to that effect and I received reimbursement for my expenses associated with pump replacement.
